04 powerstroke - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 25th, 2013, 11:31 AM   #21
yj-woody
member
yj-woody's Avatar
Ok I put the new turbo on. Turbo works great. No over boosting anymore. I hooked up to my trailer and put my jeep on it. Have no power towing at all. It's like I am trying to pull my jeep with a ford ranger. It's really bad.. What could this be? Put new fuel filters in. When I did the turbo and oil change.... Help please... Thanks
yj-woody is offline   Reply With Quote
Old January 25th, 2013, 11:45 AM   #22
special k
special k's Avatar
Vgt solenoid only allows oil into the turbo to control vgt function. The boost pressure is read off of the map sensor on the heater box. Cracked up pipe on the passenger side if y pipe on drivers side can also create lack of power concerns and will magnify while towing as the load is there but turbo cannot be spooled with the leak. But most likely if it sat a long time the unison ring is seized
Old January 25th, 2013, 11:51 AM   #23
yj-woody
member
yj-woody's Avatar
Just put a new turbo on it. The turbo works great. Nothing wrong with the turbo now. Just put the turbo on Monday and a new drain pipe. I can feel the Difference with this turbo. But still now towing power..
Old January 25th, 2013, 12:28 PM   #24
firehawk
Live Action!
firehawk's Avatar
Have you driven a diesel before?
Old January 25th, 2013, 12:39 PM   #25
yj-woody
member
yj-woody's Avatar
Yes. I have. And this one has no balls. My buddy has a 03 and pulls a 30 ft gooseneck. Mine can't even pull a 18ft car trailer with a jeep on it with out dropping speed from 70 to 45 going up a small hill.
Old January 25th, 2013, 12:42 PM   #26
firehawk
Live Action!
firehawk's Avatar
Auto trans?
If so does it downshift?
Old January 25th, 2013, 12:44 PM   #27
yj-woody
member
yj-woody's Avatar
Yes auto. It don't down shift. Just dogs down..
Old January 25th, 2013, 12:48 PM   #28
firehawk
Live Action!
firehawk's Avatar
That could be your problem, the trans.
Have you tried to manually downshift it?
Old January 25th, 2013, 12:49 PM   #29
Tacker
Tacker's Avatar
Probably blew a head gasket with all of the overboost problems....
Old January 25th, 2013, 12:50 PM   #30
yj-woody
member
yj-woody's Avatar
I will have to try that tonight.. Thanks
Old January 25th, 2013, 12:51 PM   #31
yj-woody
member
yj-woody's Avatar
Thanks Terry I really wanted to hear that...
Old January 25th, 2013, 12:56 PM   #32
tvandyck7
OlllllllO
tvandyck7's Avatar
Try unplugging the egr valve and leaving unplugged. If it is an 04, it won't throw a CEL. I drove my 04 for 2 years with it unplugged without a problem. Mine had no balls pulling up hills until I unplugged that stupid valve.
tvandyck7 is offline   Reply With Quote
Old January 25th, 2013, 01:00 PM   #33
yj-woody
member
yj-woody's Avatar
I did up plug it last night. It made it better. But still.. Did you every find out why your was a dog?
Old January 25th, 2013, 01:06 PM   #34
tvandyck7
OlllllllO
tvandyck7's Avatar
Once I unplugged the egr valve it came back to life.
Old January 25th, 2013, 01:07 PM   #35
tvandyck7
OlllllllO
tvandyck7's Avatar
I had a straight pipe and programmer on mine and rarely ever drove it in stock form.
Old January 25th, 2013, 01:10 PM   #36
tvandyck7
OlllllllO
tvandyck7's Avatar
Look at some of my posts from a few years back on the dieselstop.com. I have some pretty extensive write ups on there. I am tvandyck7 on there too.
Old January 25th, 2013, 03:54 PM   #37
yj-woody
member
yj-woody's Avatar
Ok i will have to check you out on there.. Thanks
Old February 21st, 2013, 10:02 PM   #38
special k
special k's Avatar
i know it's a pretty stupid question, but is the air filter clean? don't go by the filter minder but actually by the front side of the filter. also could be a lack of fuel volume under load. the only way to truly check that is with the otc gauge that will allow you to simulate wide open throttle.
Old June 28th, 2013, 05:35 PM   #39
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
Where did you get to with this??? Curious...
Cheap Thrills Off Road
Old June 28th, 2013, 05:57 PM   #40
He traded it in on a new truck .
Page generated in 0.42297 seconds with 83 queries
