4WD Service Light... tcase swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 13th, 2013, 05:38 PM   #1
j_little3
Boris
j_little3's Avatar
Default 4WD Service Light... tcase swap
I have a 2000 Silverado 2500 with a SAS. I swapped the 246 tcase out with a 241 and the new case has only 1 electrical connection where the 246 had multiple so I would say that is why the light is on but does anyone know how to disable the "Service 4WD" light?
I now have the manual tcase by the way.
Thanks
j_little3 is offline   Reply With Quote
Old January 14th, 2013, 09:55 AM   #2
Cool parts peddler
Ironman Offroad's Avatar
Remove the 4wd fuse.
Old January 14th, 2013, 03:15 PM   #3
j_little3
Boris
j_little3's Avatar
I removed the ATC fuse but no luck
Old January 14th, 2013, 05:55 PM   #4
j_little3
Boris
j_little3's Avatar
SAS help
Old January 15th, 2013, 11:24 AM   #5
j_little3
Boris
j_little3's Avatar
No one has experience with this?
Old January 15th, 2013, 11:31 AM   #6
tonkatruckon44s
tonkatruckon44s's Avatar
remove the light bulb in the dash or put electical tape over it
tonkatruckon44s is offline   Reply With Quote
Old January 15th, 2013, 12:56 PM   #7
deerebowtie
Unchained
deerebowtie's Avatar
is your speedometer working in 4x4 hi and low? is your truck stuck in limp mode, or are you just looking to get rid of the warning light?
Old January 15th, 2013, 03:13 PM   #8
j_little3
Boris
j_little3's Avatar
Everything works just fine as far as I know... Im just looking to get rid of the light.
Old January 15th, 2013, 03:56 PM   #9
deerebowtie
Unchained
do what ironman said - or list vehicle/options and some tech details of what was removed/disconnected during the SAS swap. Then lets see if we can drum up a schematic and iron out where its not working so you don't make troubleshooting down the road more difficult?
Old January 15th, 2013, 04:10 PM   #10
j_little3
Boris
j_little3's Avatar
Ive removed both the 4WD and the ATC fuse, both had no effect. The only plug that is plugged in is the VSS
Old January 15th, 2013, 06:30 PM   #11
deerebowtie
Unchained
you aren't giving any details, so read through this on your own and it should get you fixed.
http://www.fullsizechevy.com/forum/g...p-writeup.html
Old January 16th, 2013, 10:47 AM   #12
j_little3
Boris
j_little3's Avatar
Idk what other details you need. All I want is to disable the "service 4wd" light. I have a 2000 2500 silverado "new body style" with the 6.0L and 4L80E trans, I had the NP246 tcase and swapped it with the NP241. The truck has a SAS from a late 70's dana 44 with manual hubs so I dont need the actuator. The only plug required on the 241 is the VSS which is plugged in and controls the speedo perfect. I have alot of extra pigtails not connected to anything because they are not required for anything I need. I have not done anything with the 4lo issue yet but that is now what I am after. I suppose I can completely remove the 4wd module because the transfer case is manual (when it is in 4wd, it is in, no question). I will have to figure something else out for the 4lo shifting issue.
Old January 16th, 2013, 05:17 PM   #13
Cool parts peddler
You have the "Service 4WD" message displayed in the center of the instrument cluster?
Or a "Service 4wd" amber light iluminated?
Either way, If that is the issue, the Transfer Case Control Modual (TCCM) is sending a message to the instrument cluster. The only way to disable that message would be reprogramming as far as I know.
Someone jump in and educate me if I am wrong.
Old January 16th, 2013, 05:58 PM   #14
deerebowtie
Unchained
did you read any DTC's?
here's the likely rundown:
Subject: Service 4WD Indicator Illuminated, DTC B2725 Set (Replace Transfer Case Shift Control Switch) #02-04-21-004 - (04/15/2002)
Models: 1999-2002 Chevrolet and GMC C/K Pickup and Utility Models (Silverado, Sierra, Avalanche, Suburban, Tahoe, Yukon, Yukon XL)
with Four Wheel Drive and NVG 236/246 Transfer Case (RPO NP8)
Now...your truck doesn't require anything but the purple & green wired vss from the 246 and a working 4x selector switch to live happily in 4-hi. To use 4-low you'll need to wire in some kind of toggle switch to ground this pin on the TCCM plug:
Google + reading can go a really long way. Please fill in the details if I'm wrong or missing something.
Old January 16th, 2013, 08:30 PM   #15
j_little3
Boris
j_little3's Avatar
Okay, this doesnt answer my question so being a smart ass isnt helping.
I. Am. Trying. To. Get. Rid. Of. The. Warning. Light.
Old January 17th, 2013, 08:06 AM   #16
superchevy1080
gun nut
superchevy1080's Avatar
Most sensors run on a grounding system, so check to see if you have a 12v signal, or if its just a ground or both, in most cases you can get away with grounding out the signal wire. I would not apply 12v to any of the wires in fear of frying everything.
superchevy1080 is offline   Reply With Quote
Old January 17th, 2013, 10:57 AM   #17
j_little3
Boris
j_little3's Avatar
The "service 4wd" light is part of the led display that displays low fuel, change oil, things like that. Idk if I can just ground a wire to fix that issue. There are about 3 plugs that are no longer plugged into anything when I did the swap because there was no need for them so idk. maybe I will just have to deal with it.
This is the message.
http://i289.photobucket.com/albums/l...y/DSC05232.jpg
Old January 18th, 2013, 01:24 PM   #18
Cool parts peddler
The pic helps a lot.
I believe the cluster will need to be reprogrammed for a 2wd vehicle as I do not believe a manual transfer case was available.
Old January 18th, 2013, 09:27 PM   #19
78mitsu
Still missing Moab
It's most likely the computer is detecting the absence of the encoder motor and position sensors. If you have your old transfer case the encoder motor is on the front just below the and to the right of the front propshaft. has a cable that runs off it to the harness with about 7-8 wires. I'd start by removing it from your old transfer case and plugging it into the harness. there is a void in the selector shaft that tells a magnetic sensor the position of the selector. I've used a socket with a .250 notch cut to diagnose the sensor. Make not of the position when you remove it from the old case. There are a few other things that may cause it, but this is the most likely. Do you have DTCs you could share?
78mitsu is offline   Reply With Quote
Old January 19th, 2013, 02:20 PM   #20
j_little3
Boris
j_little3's Avatar
If I reprogram the truck to be a 2wd wont that not allow for it to shift correctly in 4lo because it wont know what 4lo is?
Page generated in 0.39063 seconds with 83 queries
