Engine Rebuilder / Builder - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 13th, 2013, 05:38 PM   #1
Bow_Extreme
Bow_Extreme's Avatar
Default Engine Rebuilder / Builder
I'm looking for someone who can rebuild a 5.3L V8 Trailblazer engine. I believe this has the active fuel management. I'm looking for a very reputable shop or individual who knows these engines very well. I'm in the Holland, MI. area but would drive to most any Michigan location for the right builder.
Thanks
Bow_Extreme is offline   Reply With Quote
Old January 14th, 2013, 08:42 AM   #2
frdboy
frdboy's Avatar
Thanks
What's wrong with it? Stock rebuild or something better?
It is something we could do, give me a shout if interseted.
Adam
Mike's Mobil Inc.
616-396-5635
Old January 15th, 2013, 04:23 PM   #3
GREASYHANDS
GREASYHANDS's Avatar
Originally Posted by frdboy View Post
what's wrong with it? Stock rebuild or something better?
Adam
mike's mobil inc.
616-396-5635
x2
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old February 27th, 2013, 09:17 AM   #4
bww3588
It really takes someone who knows ls engines to build them. I believe the trail blazer had the lh6 aluminpt 5.3 with afm. You need to decide if you want to keep that or delete it because the cam profiles are different, the valley cover has to be changed and the oil towers have to be drilled, tapped and plugged.
The blocks are pretty straight forward, but can only be bored and honed very little. Also, you need to find a machine shop with an ls torque plate to have it honed. The aluminum block engines are very sensitive to block distortion between heads on and heads off.
Best advice I can give you after building quite a few of these and building many old small blocks is...
If you walk into a machine shop and they have never seen/heard of an ls series engine, walk out. These engines have a lot of little quirks and other things that have to be done just right or you can ruin the entire engine.
If you have any questions or anything, pm me.
bww3588 is offline   Reply With Quote
Old February 27th, 2013, 09:18 AM   #5
FORD FLARESIDE
just hockey
FORD FLARESIDE's Avatar
Adam
Mike's Mobil Inc.
616-396-5635
x3
Page generated in 0.27462 seconds with 38 queries
