7075 T-6 Aluminum Links - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old January 12th, 2013, 11:00 AM   #1
RockSolid Perf.
RockSolid Performance
RockSolid Perf.'s Avatar
Default 7075 T-6 Aluminum Links
RockSolid Performance 7075 Aluminum links
Tired of bending your steel tube links? Trying to shave some weight off your rig? These RSP 7075 Aluminum links will hold up to a serious pounding. Guys have been running this style link for a long time at KOH and more. We are now offering on our website Aluminum links available in 4 tap sizes and 4 bar sizes. We offer 2 Diameter bar to for those looking to go big. Check out our web site to purchase. You can also use these for Tie rods and drag links
Tap sizes available will be
3/4-16 LH or RH
1"-14 LH or RH
7/8-14 LH or RH
1 1/4"-12 LH or RH
Price includes a 2' section drilled and tapped to your specs.
$90 1.5" diameter,2' long. Add $1.75 per inch for longer link
$95 1.75" diameter,2' long. Add $2.00 per inch for longer link
$105 2.0" diameter,2' long. Add $2.50 per inch for longer link
$120 2.25" diameter,2' long. Add $3.00 per inch for longer link
We put a bunch of Aluminum links on this suspension that we built
http://www.rocksolidperformance.com/..._signature.gif
www.RockSolidPerformance.com. We are dealers for AEV, Metalcloak, Motor State, Poly Performance, PSC, Yukon Gear. Like Us on Facebook.
RockSolid Perf. is offline   Reply With Quote
Old January 12th, 2013, 12:41 PM   #2
beejers
always building
beejers's Avatar
RockSolid Performance Aluminum 7075 T-6 Links
beejers is online now   Reply With Quote
Old January 13th, 2013, 01:04 PM   #3
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
I think the website has a mistake. It says the 1.75 links cost $143.00 for 24" instead of $95.00.
Old January 13th, 2013, 06:35 PM   #4
beejers
always building
beejers's Avatar
thanks for the heads up, we spot checked most of it. there are a ton of "RULES" to make all the options available on one part.
Old January 13th, 2013, 08:54 PM   #5
littletrucker
I'd hit that
littletrucker's Avatar
What size would be sufficient for a tie rod? I have 3/4 by 3/4 heims but i would probably go with 3/4x7/8 to be just a tad stronger.
Dana 60- 37 inch tires
Old January 15th, 2013, 08:24 AM   #6
RockSolid Perf.
Depends on how high your steering is. We use 1.5" or 1.75" depending on how much rock contact we expect.
Old March 21st, 2013, 09:42 AM   #7
RockSolid Perf.
Thanks For The Aluminum Link orders. Lots of guys replacing their bent steel links before the wheelin season goes full swing.
Old September 16th, 2013, 03:30 PM   #8
RockSolid Perf.
Your steel Link bars bent or just want to upgrade before they do? Get these 7075 aluminum link bars. These things are indestructible. All Orders placed by 9/30/2013 Will get free Wrench flats and custom name engraving!!!!!!! Call to order 616-696-8114
Old September 16th, 2013, 04:24 PM   #9
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I would like one for a tierod but would need a tab welded to it for my ram to attach to....that possible?
Old September 16th, 2013, 04:39 PM   #10
RockSolid Perf.
7075 Aluminum cannot be welded to therefore we have designed CNC machined clamp to clamp on the tie rod. The clamp is $65 dollars.
Old September 17th, 2013, 07:47 AM   #11
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I looked through the website and couldn't find a picture of the clamp.....do you happen to have one? Will it hold tight enough to accommodate full hydro and 40's?
Old September 17th, 2013, 08:11 AM   #12
RockSolid Perf.
The Tie rod is turned down to a slightly smaller DIA. where the clamp goes to prevent it from moving.
Old October 7th, 2013, 04:22 PM   #13
RockSolid Perf.
The Last order of Free Custom engraved 7075 Aluminum Link bars from Septembers Sale went out today!!!!! Thanks For The Orders!!!!!!!
Thread Tools
Page generated in 0.28024 seconds with 63 queries
