Looking for book for How to Hot Rod AMC V8 thousands available for chevy - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 12th, 2013, 08:13 AM   #1
Bo's Cj 7
Bo's Cj 7's Avatar
Default Looking for book for How to Hot Rod AMC V8 thousands available for chevy
I have been researching building my 401 I am thinking about stroking it not sure about that, I know that the oiling system need some mod I have read enough about that I can do it, but I was looking for some how to books on AMC V8 and haven't found anything anybody have any ideas where to look?
Bo's Cj 7 is offline   Reply With Quote
Old January 12th, 2013, 08:21 AM   #2
MiNi Beast
MiNi Beast's Avatar
Barnes and noble, google it, found many books that way and dirt cheap as well.
Click to View Search Results for %C2%A0How+to+Hot+Rod+AMC+V8 Google: %C2%A0How+to+Hot+Rod+AMC+V8
Old January 12th, 2013, 09:25 AM   #3
rargreen
88
rargreen's Avatar
Contact Bruce @ Circle Auto in Freeland. He has built & helped build many AMC V8's. I know he has experience with stroking 401's & their machine shop has done a lot of AMC work.
rargreen is offline   Reply With Quote
Old January 13th, 2013, 09:42 AM   #4
Bo's Cj 7
Bo's Cj 7's Avatar
How to Hot Rod AMC V8 - Google Search
I didn't see anything on hot rodding or performance engines
Old January 13th, 2013, 09:56 AM   #5
Red68Camaro
End nerd persecution
Red68Camaro's Avatar
I found these sites helpful when I built my 360 a few years ago.
http://theamcforum.com/forum/
http://www.bulltear.com/
http://southtexasamc.tripod.com/
http://www.carcraft.com/techarticles...s/viewall.html
Red68Camaro is offline   Reply With Quote
Old January 13th, 2013, 06:16 PM   #6
AFRd_CJ5
AFRd_CJ5's Avatar
I don't believe anybody makes a direct drop in stroked crankshaft for a 401. You would either have to offset the journals or have a custom crank made. I've seen some damn good running AMC's, but the problem is above. Not enough aftermarket for them, and it can get very expensive very quick. I haven't look in a while, but if you happen to find something, I'd be interested in hearing. My brother in law runs AMC stuff
AFRd_CJ5 is offline   Reply With Quote
Old January 13th, 2013, 06:41 PM   #7
Bo's Cj 7
Bo's Cj 7's Avatar
I may contact Bruce the other guy suggested, at this point my crank was already turned 20 20 and it spun a rod bearing and that journal is worn and scared to 30 so the only way to use it would be to cut the rod journals down to 2.100 chevy size. So might as well offset it and buy chevy rods just having some trouble finding a the correct piston pin height piston.
Old January 13th, 2013, 07:23 PM   #8
jeepers48
jeepers48's Avatar
I have a 401 crank if your interested, never turned.
amc 401 crank $300. now w/pcs - Great Lakes 4x4. The largest offroad forum in the Midwest
pm me if interested.
jeepers48 is offline   Reply With Quote
Old January 13th, 2013, 07:39 PM   #9
itselliott
itselliott's Avatar
Look up screen name GHINMI at IFSJA.ORG.
Old January 14th, 2013, 09:33 AM   #10
Bo's Cj 7
Bo's Cj 7's Avatar
I seen your crankshaft for sale and have been thinking about it, I have a friend with similar problem as my self but his is turned 30 on mains and need to be turned again so he need the new crank more than me. I tried to talk him into putting it in a 360 block that way you turn down the mains also. I will keep you in mind. Will you be going to West branch to any of the snow runs?
Old January 14th, 2013, 09:46 PM   #11
jeepers48
jeepers48's Avatar
pm'd you. WestBranch/Sno-blind weekend in Feb.
Page generated in 0.38330 seconds with 57 queries
