Pro Street Big Block FoxBody Mercury Capri, Needs finishing: - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 11th, 2013, 12:46 PM   #1
DarrinGT
DarrinGT's Avatar
Default Pro Street Big Block FoxBody Mercury Capri, Needs finishing:
Pro Street 1981 Mercury Capri project. Turn key Runs and Drives, Needs finishing, body work and paint. Approximately 50 miles on the build, (motor , Trans, rear end etc) but has been sitting inside for a long time. The motor is a 1969 429 Big Block, 11-1 Compression, Ported intake, 800 Holly, 1.6 Roller Rockers, Cam, Pete Jackson Gear Drive, Headers, 3" Exhaust, Built C6 Trans, 3000 Stall Converter, Ratchet Shifter, 3:55 Gears 9" Rea end, (open, Needs a Locker) 4 wheel Disk Brakes, 5 lug conversion, Electric Fuel Pump, , 375-60-15 tires on 14" wide Centerlines, Matching 3.5 Skinny's up front, Fuel Cell, Roll Cage, Tubbed Up, Electric Fan. Drive shaft Loop, Welded in sub frame connectors, 4link rear suspension, adjustable coil overs, big block spring up front, Runs Very Strong, Drives great, Sounds AWESOME, All factory accessories, lights, heater, gauges work, There is some rust on the car that needs to be repaired, finishing in the interior, It does come with both front buckets, extra rust free Passenger Door, and Rear back hatch with spoiler. All of the HARD WORK has been done, Nice Stance Good Build, Nothing exotic but it all works great!
This car is owned and built by a 30 year certified Mechanic, Bob Houskamp, Please give him a call at his shop to set up a time to look at it and he cal tell you all about it as well. 616-281-3768
Price is $4950.00
I have a lot more pics if that I would be glad to email to you if interested.
Located in Grand Rapids Mi.
Name:	Bob's 1981 Mercurey Capri 001.jpg
ID:	100417   Click image for larger version
Name:	Bob's 1981 Mercurey Capri 003.jpg
ID:	100418   Click image for larger version
Name:	Bob's 1981 Mercurey Capri 037.jpg
ID:	100419   Click image for larger version
Name:	Bob's 1981 Mercurey Capri 022.jpg
DarrinGT is offline   Reply With Quote
Old January 11th, 2013, 02:56 PM   #2
DarrinGT
DarrinGT's Avatar
Here is Bob having a little fun with his Hot Rod:
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Page generated in 0.18013 seconds with 30 queries
