05 Sierra LS problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 8th, 2013, 02:22 PM   #1
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
Default 05 Sierra LS problem
So over Christmas I started having this little problem with my rear diff.
When I took off with one tire on dry pavement and one on snow, the one on snow would slip and then the diff would lock up with a BOOM. I would then take off because the rear end locked up.
If the tire that tire on dry pavement hit a patch of snow, it would repeat the process with another BOOM. Meaning it will unload and reload back up as I move forward or reverse.
Sometimes for no random reason the rear end will "lock" and I'll be driving around with a spool with no better explanation.
I bought this truck used in May. At this point I have no reason to believe its anything other than a stock GM limited slip. I'm at a loss as this is the first LS I've had with this sort of problem.
Discuss.
ckupq is offline   Reply With Quote
Old January 8th, 2013, 02:34 PM   #2
silveradoboy
Sam Brown
silveradoboy's Avatar
My new truck will do this as well sometimes. Just the G80 locking up? I had to use 4x4 for a small amount of time and when I went back to 2wd the rear end would stay locked up
silveradoboy is offline   Reply With Quote
Old January 8th, 2013, 02:47 PM   #3
ckupq
ckupq's Avatar
Yea Its got a G80 and after watching a couple of videos I see what is happening with mine. While I don't think there is anything too wrong with it, I'm still gonna have it looked at to make sure everything is OK back there.
Is there anything I should have looked at to see if its bent or broken?
Old January 8th, 2013, 02:54 PM   #4
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
change the fluid and put the gm additive in it.
Old January 8th, 2013, 03:27 PM   #5
kickstand
circling the drain
kickstand's Avatar
common problem, do as hosejockey said.
Old January 8th, 2013, 03:29 PM   #6
IFS SUCKS
I like trees
IFS SUCKS's Avatar
Rear Axle
This is right from the gm service manual
SAE 75W-90 Synthetic Axle Lubricant (GM Part No. U.S. 12378261, in Canada 10953455) meeting GM Specification 9986115.
IFS SUCKS is offline   Reply With Quote
Old January 8th, 2013, 03:42 PM   #7
IFS SUCKS
I like trees
IFS SUCKS's Avatar
PIP3001B: Light Duty Truck Rear Axle Lubrication Service Interval - keywords lube - (May 21, 2009)
Subject:
Models:
2000-2010 Cadillac Escalade, Escalade ESV, Escalade EXT
2002-2010 Chevrolet Avalanche
2002-2009 Chevrolet Trailblazer
2000-2010 Chevrolet Express, Suburban, Tahoe
2000-2007 Chevrolet Silverado Classic
2007-2010 Chevrolet Silverado
2000-2004 Chevrolet S-10
2003-2006 Chevrolet SSR
2000-2005 Chevrolet Astro, Blazer
2004-2010 Chevrolet Colorado
2004-2010 GMC Canyon
2000-2009 GMC Envoy
2000-2010 GMC Savanna, Sierra Denali
2000-2007 GMC Sierra Classic
2007-2010 GMC Sierra
2000-2010 GMC Yukon, Yukon XL, Yukon XL Denali
2000-2004 GMC Sonoma
2000-2005 GMC Jimmy, Safari
2003-2009 Hummer H2, Hummer SUT
2006-2009 Hummer H3
2000-2004 Oldsmobile Bravada
Condition/Concern:
The service information and owners manual do not show a service interval for the 7.6, 8.6, 9.5, 9.75, 10.5, and 11.5 inch rear axles with or without G80 (locking differential).
Recommendation/Instructions:
These axles do not need to be serviced under normal operation due to the synthetic fluid that is used from the manufacturer. Please refer to the owner's manual for any questions regarding axle fluid change information.
Old January 8th, 2013, 08:58 PM   #8
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
That would be a fairly normal characteristic of any working G80 differential. Mind you they are a LOW speed traction device. They are not strong enough for holeshots or burnouts, or full throttle on loose surfaces. It may last for a little while with abuse but when they fail it's catastrophic.
Page generated in 0.26346 seconds with 47 queries
