460 ford ranger-pics n vids up - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 23rd, 2013, 08:30 PM   #21
robn69
robn69's Avatar
This is what I did with the arm mounts on the ranger I'm building
Oh and I extended the arms
robn69 is offline   Reply With Quote
Old January 25th, 2013, 09:46 PM   #22
nightstalker00
nightstalker00's Avatar
i like it. the one thing i didnt like about the mount i made was to low. i like how yours is just below frame. im sure this project will under go many changes over time. this design is something i will keep in mind.
yours is a ranger also? with fullsize axles?
nightstalker00 is offline   Reply With Quote
Old February 5th, 2013, 09:11 PM   #23
robn69
robn69's Avatar
Yea hp Dana 44 and ford 9"
Old March 8th, 2013, 09:02 PM   #24
nightstalker00
its been a while and I will get some pics up but two motors later ended up with a 87 460. dropped it in and fired it up. will get up date pics tomarrow. still gotta plumb radiator, run brake lines, and build drive shafts.
Old March 21st, 2013, 05:35 PM   #25
nightstalker00
yes its taken a little while to get these up. so progress made got pump mounted plumbed and guarded.
rear rad lines routed, welded, and tested.
newer motor with less miles in and hooked up.
test fired everything seemed ok till i let go of the push button. did some research and called a friend. turned out some of the aftermarket producers of the duraspark box flipped wires. problem was it would fire up and die. so checked plug going into box from truck harness, they were reversed. problem solved she runs. next step is alternator. motor is out of an 87.
k so coming off the alternator i have the original plug. did some digging online there are just three connections. one is to bat side of solenoid for charge wire. second is red wire for pwr from key. third is a white/ yellow from what i could find this wire would just go to side of solenoid with charge wire. this doesnt work as soon as i disconnect bat it dies.
Any ideas?
Old March 24th, 2013, 07:51 PM   #26
nightstalker00
still open to suggestions on how to wire up alternator. how can i test what i already have wired up?
Old March 27th, 2013, 09:15 PM   #27
nightstalker00
got a new intake and cleaned it up a bit. not looking to bad.
then ordered some tube to start roll cage.
came along pretty good. still work to be done but the complicated work is done.
Old June 8th, 2013, 07:38 PM   #28
nightstalker00
k so a little update. well its done.....done broke! hahahaha
dont know if this will work but i will try.
https://www.facebook.com/photo.php?v...type=2&theater
time to take it out for the first time.
nice pic
looks good dirty
time to take her home in pieces
Old June 8th, 2013, 07:59 PM   #29
nightstalker00
so the problem is front drive line angle. cure going to try a clocking plate for now. anyone ever use one?
i did take previously mentioned advice and replaced rear coils with 6in rear coils from a jeep. it rides nice
Old June 18th, 2013, 06:55 PM   #30
nightstalker00
took it out to test her out after trans was repaired.
all is well
Old July 13th, 2013, 11:09 PM   #31
nightstalker00
some new 2wd vids. everything worked good.
Tags
460, 4link, ford ranger, mud truck
Page generated in 0.43863 seconds with 56 queries
