utv's ans side by sides (razors etc.) - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Land Use > Rules, Regulations, Trail, and ORV Park Chat
Old January 7th, 2013, 09:26 PM   #61
kixx007
Certified Ypsilantian
kixx007's Avatar
Why?
You hurt my emotions.
kixx007 is offline   Reply With Quote
Old January 7th, 2013, 09:30 PM   #62
signman
I didn,t have a tape with me. They were from the Clare Co Sheriff,s Posie and I know the riders range scores!!!
signman is offline   Reply With Quote
Old January 7th, 2013, 09:40 PM   #63
signman
Have we answerd the question ?
( I just run a chainsaw and posthole digger, I DON,T MAKE THE RULES!!!)
Old January 7th, 2013, 10:43 PM   #64
kb8ymf
Not as old as Whiterhino
kb8ymf's Avatar
Originally Posted by oz97tj View Post
Is the Belgian less than 50 inchs wide?
First glance would be they might be legal on an ORV Trail. Less than 50", check, Straddled by rider, check, but they may fall short on the 'fuel' aspect. It does say comparable fuel but it must power an engine. Engine is not defined so it might be a grey area.
(a) "ATV" means a 3-, 4-, or 6-wheeled vehicle designed for off-road use that has low-pressure tires, has a seat designed to be straddled by the rider, and is powered by a 50cc to 1,000cc gasoline engine or an engine of comparable size using other fuels.
That's where I'd get hung up. BUT, because there are NO exclusions for them like snowmobiles it might be arguable.
jim
kb8ymf is offline   Reply With Quote
Old January 7th, 2013, 11:20 PM   #65
oz97tj
Wasn't this attached?
oz97tj's Avatar
jim
You're thinking like an engineer again.
Cops think like this.... "uh........................................... ... Looks good to me" or "uh............................................... ..............you's gettin a ticket!" or "mmmmmmmmmmmm doughnuts"
********GLFWDA.org********
Old January 8th, 2013, 02:57 AM   #66
signman
CHECK THIS OUT
Motorized Trails: All designated motorized trails on state owned land allow for
non-motorized trail activities along the same corridor. When these corridors cross
onto other public lands or private land, the trail purpose reverts back to its single
be permitted. Although these other uses are not specifically restricted from state
owned corridors, the DNR has not evaluated the appropriateness of these uses
on these corridors. All non-motorized use groups, including EQs, should use
these corridors with caution. Detailed snowmobile maps can be found at:
http://www.michigan.gov/dnr/0,4570,7-153- 10365_14824-31074--,00.html
ORV maps can be found at:
Old January 8th, 2013, 10:39 AM   #67
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
huh?
First glance would be they might be legal on an ORV Trail. Less than 50", check, Straddled by rider, check, but they may fall short on the 'fuel' aspect. It does say comparable fuel but it must power an engine. Engine is not defined so it might be a grey area.(a) "ATV" means a 3-, 4-, or 6-wheeled vehicle designed for off-road use that has low-pressure tires, has a seat designed to be straddled by the rider, and is powered by a 50cc to 1,000cc gasoline engine or an engine of comparable size using other fuels.
jim
324.81101 Definitions.
Sec. 81101.
As used in this part:
(a) "ATV" means a 3-, 4-, or 6-wheeled vehicle designed for off-road use that has low-pressure tires, has a seat designed to be straddled by the rider, and is powered by a 50cc to 1,000cc gasoline engine or an engine of comparable size using other fuels.I have the 2009 book at home it said 500cc, so hense the 500cc comment I made earlier
(b) "Code" means the Michigan vehicle code, 1949 PA 300, MCL 257.1 to 257.923.
(c) "Dealer" means a person engaged in the sale, lease, or rental of an ORV as a regular business or, for purposes of selling licenses under section 81116, any other person authorized by the department to sell licenses or permits, or both, under this act.
(d) "Designated", unless the context implies otherwise, means posted open for ORV use with appropriate signs by the department.
(e) "Farm vehicle" means either of the following:
(i) An implement of husbandry as that term is defined in section 21 of the Michigan vehicle code, 1949 PA 300, MCL 257.21.
(ii) A vehicle used in connection with a farm operation as that term is defined in section 2 of the Michigan right to farm act, 1981 PA 93, MCL 286.472.
(f) "Forest road" means a hard surfaced road, gravel or dirt road, or other route capable of travel by a 2-wheel drive, 4-wheel conventional vehicle designed for highway use, except an interstate, state, or county highway.
(g) "Forest trail" means a designated path or way capable of travel only by a vehicle less than 50 inches in width.
(h) "Highway" means the entire width between the boundary lines of a way publicly maintained when any part of the way is open to the use of the public for purposes of vehicular travel.
(i) "Highly restricted personal information" means an individual's photograph or image, social security number, digitized signature, and medical and disability information.
(j) "Late model ORV" means an ORV manufactured in the current model year or the 5 model years immediately preceding the current model year.
(k) "Manufacturer" means a person, partnership, corporation, or association engaged in the production and manufacture of ORVs as a regular business.
(l) "Off-road vehicle account" means the off-road vehicle account of the Michigan conservation and recreation legacy fund established in section 2015.
(m) "Operate" means to ride in or on, and be in actual physical control of, the operation of an ORV.
(n) "Operator" means a person who operates or is in actual physical control of the operation of an ORV.
(o) "ORV" or "vehicle" means a motor-driven off-road recreation vehicle capable of cross-country travel without benefit of a road or trail, on or immediately over land, snow, ice, marsh, swampland, or other natural terrain. ORV or vehicle includes, but is not limited to, a multitrack or multiwheel drive vehicle, an ATV, a motorcycle or related 2-wheel, 3-wheel, 4-wheel, or 6-wheel vehicle, an amphibious machine, a ground effect air cushion vehicle, or other means of transportation deriving motive power from a source other than muscle or wind. ORV or vehicle does not include a registered snowmobile, a farm vehicle being used for farming, a vehicle used for military, fire, emergency, or law enforcement purposes, a vehicle owned and operated by a utility company or an oil or gas company when performing maintenance on its facilities or on property over which it has an easement, a construction or logging vehicle used in performance of its common function, or a registered aircraft.
(p) "Owner" means any of the following:
(i) A vendee or lessee of an ORV that is the subject of an agreement for the conditional sale or lease of the ORV, with the right of purchase upon performance of the conditions stated in the agreement, and with an immediate right of possession vested in the conditional vendee or lessee.
(ii) A person renting an ORV, or having the exclusive use of an ORV, for more than 30 days.
(iii) A person who holds legal ownership of an ORV.
(q) "Person with a disability" means a person who has 1 or more of the following physical characteristics:
(i) Blindness.
(ii) Inability to ambulate more than 200 feet without having to stop and rest during any time of the year.
(iii) Loss of use of 1 or both legs or feet.
(iv) Inability to ambulate without the prolonged use of a wheelchair, walker, crutches, braces, or other device required to aid mobility.
(v) A lung disease from which the person's expiratory volume for 1 second, when measured by spirometry, is less than 1 liter, or from which the person's arterial oxygen tension is less than 60 mm/hg of room air at rest.
(vi) A cardiovascular disease from which the person measures between 3 and 4 on the New York heart classification scale, or from which a marked limitation of physical activity causes fatigue, palpitation, dyspnea, or anginal pain.
(vii) Other diagnosed disease or disorder including, but not limited to, severe arthritis or a neurological or orthopedic impairment that creates a severe mobility limitation.
(r) "Personal information" means information that identifies an individual, including an individual's driver identification number, name, address not including zip code, and telephone number, but does not include information on ORV operation or equipment-related violations or civil infractions, operator or vehicle registration status, accidents, or other behaviorally-related information.
(s) "Public agency" means the department or a local or federal unit of government.
(t) "Roadway" means that portion of a highway improved, designated, or ordinarily used for vehicular travel. If a highway includes 2 or more separate roadways, the term roadway refers to a roadway separately, but not to all roadways collectively.
(u) "Route" means a forest road or other road that is designated for purposes of this part by the department.
(v) "Safety chief instructor" means a person who has been certified by a nationally recognized ATV and ORV organization to certify instructors and to do on-sight evaluations of instructors.
(w) "Visual supervision" means the direct observation of the operator with the unaided or normally corrected eye, where the observer is able to come to the immediate aid of the operator.
Old January 8th, 2013, 12:49 PM   #68
signman
It is amazing the DEPT doesn,t know yet. BUT HERE IS A ORV AND SNOWMOBILE MAP LINK
Old January 8th, 2013, 01:51 PM   #69
alboy79
Where's your loyalty lie?
alboy79's Avatar
Location: Comstock Park, Michigan or 49321 for shipping
Per Muskegon_zj-gurls request....
"Skill that is untested does not equate to actual skill." Test yourself!
Don't tell me what you've done.
Show me what you can do.
alboy79 is offline   Reply With Quote
Old January 8th, 2013, 02:26 PM   #70
oz97tj
oz97tj's Avatar
But it only mentions UNDER 50 and OVER 50. It doesn't mention the ones that are exactly 50. What are wegoing to do?!?
Old January 8th, 2013, 02:45 PM   #71
MusKegon_ZJ_gurl
Extraordinarily Ordinary
MusKegon_ZJ_gurl's Avatar
We are going to park it in the fu*#ing garage till it turns to dust, thats what we're gonna do!
http://www.glfwda.org/
MusKegon_ZJ_gurl is offline   Reply With Quote
Old January 8th, 2013, 02:46 PM   #72
Shoot them.
Old January 8th, 2013, 06:07 PM   #73
kb8ymf
kb8ymf's Avatar
As I indicated, as soon as there is an uprising there will be a decision.
Go look at this eye chart. Not sure they are all up to to date though. Wisconsin for a fact is not and neither is Michigan.
http://www.atvsafety.org/infosheets/...t-statereq.pdf
Here's what I found elsewhere.
Oregon:
So they banned all SxS's even if they fell within the 50 inch width and less than 1200lbs on Class I trails by adding this phrase to Class I "Have handle bar steering and straddle seat". It appears the three land managers did not want to make and exeption for any SxS's and could care less about safey for ATV riders with disabilities.
Idaho:
Must have handle bars to steer
Must have seat that has to be straddled to ride
I find these clearly stating " No RZR's"
Wisconsin:
Just passed theuir law and it is 65". This will create havoc in the UP for sure. The National Forests still say 50" according to what I've read. I take that to be 50" or less. However I'm not sure what law the Federal land follows. Usually the law of the state the trails ar located.
Colorado:
Colorado includes the definition that the seat must be "straddled" and vehicle has handlebars. So, just because it fits the 50" or less criteria doesn't mean you can ride. Unless the trail is marked for use by "jeeps" a RZR is not permitted.
It look slike you ride till you get caught!
jim-kb8ymf
Page generated in 0.57339 seconds with 62 queries
