SOLD dana 60 carrier, factory trac bar & frame bracket, pair of 60 knuckles - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 5th, 2013, 02:19 PM   #1
Default SOLD dana 60 carrier, factory trac bar & frame bracket, pair of 60 knuckles
Stock 30 spline lockouts-all their but 2 cap screws. $40....$50 I'll ship
sold
Stock 88ish Inner shafts and 30 spline stubs-needs joints $100 (rather not ship)sold
Factory trac bar and frame mount $20-could use new bushings
Dually hubs, sure the rotors aren't any good. $100-Ill ship at $130 but without the rotors. SOLD
CheapThrillB2 is offline
Old January 5th, 2013, 02:52 PM   #2
I also have 95 front 60 knuckles (they need new ball joints). I installed tapered studs to use 7/8 hiems over the top of the tie rod hole. Tie rods will not work with my knuckles.
Knuckles with tapered studs $150 w/ taperd studs, $100 without you'll have to drill the holes for bolts
Old January 6th, 2013, 07:07 PM   #3
Tom
Because racecar
Tom's Avatar
Are you going to snowfari? I'm interested in the hubs, outer shafts, and d side inner shaft.
Tom is offline
Old January 6th, 2013, 07:10 PM   #4
I am.
Old January 6th, 2013, 07:39 PM   #5
Tom
Because racecar
Tom's Avatar
Do you want me to pay pal you monies or do you want cash at snowfari?
Or do you want me to take my pants off?
Tom is offline
Old January 6th, 2013, 07:58 PM   #6
Snofari would be fine, other offer is tempting but i think ill pass .
Old January 6th, 2013, 08:11 PM   #7
camccardell
tiger blood
camccardell's Avatar
interested in knuckles! No studs needed.
anything u looking for? partial trade maybe?
camccardell is offline
Old January 6th, 2013, 08:17 PM   #8
Shafts and lockouts pending.sale.
Inner pass side shaft still available $40
Old January 6th, 2013, 08:20 PM   #9
Trying to fund buggy susp. Parts.
Old January 11th, 2013, 02:47 PM   #10
Dually hubs sold.
Old January 11th, 2013, 09:01 PM   #11
4SquirlAcorn
Destroyer of XJ's
4SquirlAcorn's Avatar
Anymore info on the 4.10 gear set? Looking for a good used one for my high pinion, so it needs to be reverse rotation.
4SquirlAcorn is offline
Old January 12th, 2013, 12:10 PM   #12
BeaverTown
Cuck Fancer
BeaverTown's Avatar
Send a message via Yahoo to BeaverTown
If Tranny Tom doesn't want the shafts and lockouts I too will be at Sno-Fari and will take them off your hands.
BeaverTown is offline
Old January 12th, 2013, 07:33 PM   #13
firehawk
Live Action!
firehawk's Avatar
I will take everything else and I will pay you in GUM.
firehawk is offline
Old January 14th, 2013, 06:14 PM   #14
Used 4.10 ring and pinion $40 teeth all good shape. High Pinion Reverse cut
SOLD
Old January 15th, 2013, 07:33 PM   #15
Pass inner sold
Old January 16th, 2013, 12:32 PM   #16
4.10 open carrier. Can include spiders if desired. $50.
Old January 18th, 2013, 08:52 AM   #17
I put the 35 spline spiders back in the carrier to include with the sale.
Page generated in 0.27935 seconds with 74 queries
