2000 chevy van with the 4.3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 3rd, 2013, 01:01 PM   #1
mideerslayer
NEVER GIVE UP!
mideerslayer's Avatar
Default 2000 chevy van with the 4.3
my wife has a 2000 chevy conversion van and the past few days We try to start it and it just cranks and cranks and then finally tries to turn over. well yesterday and today it does this but it tries to fire over but doesnt and I have cranked it over to the point the battery is dead.
Once it does start it runs fine and starts right up until it sits over night.
It has gas, the battery was new in april.
I know it getting fuel( i can smell it faint fumes in the engine)
I have no idea where to start as I have never worked on vans, (dont know how to get to engine)
I looked on line and the Ignition control module seems to be the one thing that sounds like it could be, but not 100% sure
mideerslayer is offline   Reply With Quote
Old January 3rd, 2013, 05:35 PM   #2
jbsjunk
Little Member
jbsjunk's Avatar
Sounds like the fuel pump is on it's way out. Not building enough pressure to start it cold. Not the first I seen do this. A fuel pressure gauge should tell you what's going on.
Old January 3rd, 2013, 05:44 PM   #3
MilwaukeeF350
Dan
1998 gmc k2500 I bought was have issue.
It wouldn't turn engine after 2 spin it kickback. New dist cap it was $56 now it turn and running fine. It was act like timing out way when dist cap was bad.
Old January 3rd, 2013, 05:46 PM   #4
jbsjunk
Little Member
jbsjunk's Avatar
No distributor on this one. Coil on plug.
Old January 3rd, 2013, 05:53 PM   #5
mideerslayer
NEVER GIVE UP!
I have done my fair share of work on trucks and cars, and it acts like its not getting spark but then I will turn the key and it try's to fire( it kinda sounds like a diesel in the cold) and then nothing.
When this happened the other day i cranked and cranked and the battery died, I went out a hr later to "look around" and just for the hell of it I turned the key and it started right up, that is why i am so confused, as it is giving so many indications but not one solid thing.
Old January 3rd, 2013, 05:56 PM   #6
MilwaukeeF350
Dan
My friend had astro it had dist cap. Just try help.
Is engine light on? Could be crankshaft position sensor since it random won't start.
Old January 3rd, 2013, 05:58 PM   #7
mideerslayer
NEVER GIVE UP!
It has come on and off a few times in the past month and it was running "ruff" to it to get scanned and they said it was a multiple misfire but nothing showed what was causing it. They the light went off one day and was running fine and now this
Old January 3rd, 2013, 07:01 PM   #8
GREASYHANDS
GREASYHANDS's Avatar
Check the amperage draw of the fuel pump with an oscilloscope
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old January 3rd, 2013, 07:26 PM   #9
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
Idk where you got that idea but all current production 4.3 V6's have a distributor
Old January 3rd, 2013, 07:32 PM   #10
jbsjunk
Little Member
jbsjunk's Avatar
It would've helped if he didn't change his post from 4.8 to 4.3 after I posted.
Old January 29th, 2013, 04:24 PM   #11
mideerslayer
NEVER GIVE UP!
well I replaced the crank position sensor and I am getting fuel and spark, but will not turn over. I have not touched it in a few weeks and the last time I did I had the battery charged(its only 10 months old), well today after replacing the cps I tried to start it and it tried to fire a few times and then the battery went dead, only after 5-10 min of off and on cranking. Not a Constance turn the key and hold it type thing.
Could the battery need charging again since it sat in the cold, or is there something else I should be looking for? All fuses checked out ok.
Thanks
Rich
Old January 29th, 2013, 04:32 PM   #12
IFS SUCKS
I like trees
IFS SUCKS's Avatar
Cap and rotor changed yet?
IFS SUCKS is offline   Reply With Quote
Old January 29th, 2013, 04:33 PM   #13
mideerslayer
NEVER GIVE UP!
new 7 months ago
Old January 29th, 2013, 04:39 PM   #14
IFS SUCKS
I like trees
IFS SUCKS's Avatar
How many miles?
Old January 29th, 2013, 04:44 PM   #15
mideerslayer
NEVER GIVE UP!
How many miles?
198,000
It was running and driving great before this happened, and right before it stopped turning over, it was running sluggish until it warmed up.
I am taking the battery in to have it recharged, and let the engine area dry out since it was in the snow and rain the past few weeks
Old January 29th, 2013, 04:47 PM   #16
IFS SUCKS
I like trees
IFS SUCKS's Avatar
Distributor gear will some times strip out especially at higher miles.
Old January 29th, 2013, 04:52 PM   #17
ssgtgaines
ssgtgaines's Avatar
Seen this ^^^ before. On 4.3's. i work in a chevy dealer. What is your fuel pressure?
ssgtgaines is offline   Reply With Quote
Old January 29th, 2013, 04:52 PM   #18
mideerslayer
NEVER GIVE UP!
I will have to pull it to check correct?
Old January 29th, 2013, 04:55 PM   #19
mideerslayer
NEVER GIVE UP!
I didnt put a gauge on it,I was basing it on the fuel rail port, where you can press it and see if fuel comes out plus I can smell fuel after cranking it a few times
Old January 29th, 2013, 04:55 PM   #20
kkodet
kkodet's Avatar
The 4.3 will not fire unless the oil pressure sensor tells it it has pressure. If the sensor is bad it will do exactly what you are saying. I had this happen on several of the 4.3 Astrovans at my old work. Just another idea.
Page generated in 0.48063 seconds with 83 queries
