dana 30 advice - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 2nd, 2013, 04:47 PM   #1
sburt1928
zombie killer
sburt1928's Avatar
Default dana 30 advice
i have a 91 yj with a 350 chevy. also 35/12.50/15 tires. i want to put a detroit locker on the front. but my friend think's i'll be braking parts left and right. and thinks i should spend my money on a dana44 and a 14 bolt.
i was just wonding what you guys think.
i dont have two grand for a set of axles and new rims.
thanks
sburt1928 is offline   Reply With Quote
Old January 2nd, 2013, 04:52 PM   #2
Schoemann
Schoemann's Avatar
Your buddy is right. youll be breaking axle shafts and joints continually with a d30 and a locker. Check into a HP30. They go cheap and are stronger than your LP 30.
Schoemann is offline   Reply With Quote
Old January 2nd, 2013, 04:54 PM   #3
buzzbrick
That boy ain't right
buzzbrick's Avatar
By the time you've built a Dana 30 to a point where it will only break most of the times you use it, you could have had a Dana 44.
The Dana 30 can survive 35's (for some amount of time anyway), it can survive a locker, and it can survive reasonable power. It cannot survive all three at once. A high pinion Dana 30 with one-piece axle shafts from the right Cherokee might do alright, provided you don't put a locker in it or go crazy on gears (the pinion gets TINY)
If you intend to keep with 35's, matched Dana 44's from a Wagoneer might be a good pick, and aren't terribly expensive.
buzzbrick is offline   Reply With Quote
Old January 2nd, 2013, 05:02 PM   #4
Tdanks76
Tdanks76's Avatar
If its offroad only and you really want the traction, why don't you just weld it? Sure you won't be able to steer as good, but with the money you save from a Detroit you could put towards a dana 44/60 or spare parts. Either way, if you lock it and it starts bouncing on the rocks, just let off the gas.
Tdanks76 is offline   Reply With Quote
Old January 2nd, 2013, 05:17 PM   #5
joe_jeep
welfare wheeler
joe_jeep's Avatar
3/4 ton ford hp 44 is pretty close spring perch wise, and much stronger.
they can be had pretty cheap.
Old January 2nd, 2013, 05:20 PM   #6
sburt1928
zombie killer
sburt1928's Avatar
well looks like i'll be saving my money too upgade too the dana 44 and the 14 bolt for the rear.
thank you
Old January 3rd, 2013, 12:18 PM   #7
toolmantim
Go lil yellow Roobicon...
toolmantim's Avatar
There is ZERO difference between a HP30 and a LP30 regarding the axle shafts and joints, they use the same parts.
I'm compensating for my manhood.
Northwest Ohio Crawlers
toolmantim is offline   Reply With Quote
Old January 3rd, 2013, 12:56 PM   #8
Dylan
Dylan's Avatar
this x2 + dana 44 has the same axle shaft yoke size and u joint as a 30 so there is no upgrade there either.
Not to say your 91 yj dana 30 can't get some upgrades from the newer dana 30, but saying that a 44 is the answer is not exactly right either.
To schomann's comment, the YJ's all had HP30's so no need to look into that.
The only difference would be the 91's (pre-95) had the smaller u-jounts (unless you somehow have an ABS version).
You can always upgrade to 1 pc shaft with 760 joints and be just as strong as a 44 in regards to the axle shafts. The pinion still comes into play though. I ran 4.56 for a while on a 95 Yj with warn cromo shafts and 760 joints with a detroit trutrac (not a real locker) without any major issues. I wasn't real easy on it either. Finally one day of foot too the floor trying to exit a mud hole and launching the front end about 3' in the air, the front pinion didn't like it. Coming down on WOT blew the ring and pinion. The shafts and u-joints held just fine.
Fast forward to installing a HP44 with mosor shafts and 760 joints 36 tsl. I blew at least 3 shafts due to WOT driving. I only had a 4.0 so its not as bad as what you are pushing to it. Point is a 44 and 30 are both about equal.
I am currently running a LP30 all stock with 3.73 and an ARB with a turbo 4.0L. So far so good. I keep the front open when going WOT and being stupid. I'm sure being open has saved a lot of $$$$ in parts.
Old January 3rd, 2013, 12:58 PM   #9
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
This and YJ's are Hp30's... It is the TJ's that are low pinion...
Cheap Thrills Off Road
Old January 3rd, 2013, 01:04 PM   #10
BigBird
BigBird's Avatar
I was running a SBC with stock yj axles for a year. Open front and limited slip rear. Never broke anything, just wheeled sensibly. Now have 44's under it. Front is locked with chromo shafts, and Spicer forged joints, hi-steer, with hydro assist. Rear is welded stock with disc brakes. Came with complete extra front chromo shafts and extra outer chromo stubs. All that for $700... That is the only reason I am running 44's or I would have waited for tons...
Unless you get a "Built Dana 44", you are likely wasting your money as they are marginally better in stock form than a Dana30... Save your money and buy a true 1 ton front.
My $0.02...
Old January 3rd, 2013, 05:36 PM   #11
kkodet
kkodet's Avatar
My $0.02...
X2
Stock 44's are kind of a pointless axle. I'd either go built XJ HP 30 or coin up for a stock Dana 60.
And for the rear, you will hate a 14 bolt and 35's. The ground clearance will be worse than a dana 35 and stock tires. For 35's I'd run a 8.8 exploder rear and call it done. The 14 bolt is basically a plow with anything under 40 inches.
Old January 3rd, 2013, 10:23 PM   #12
KCameron13
Weekend Warrior
KCameron13's Avatar
Originally Posted by Route55 View Post
X2
X2
An 8.8 rear and Dana 60 front would be a good combo. Depending how you drive, the 30 could survive. Just make some upgrades if you are going to lock it.
KCameron13 is offline   Reply With Quote
Old January 4th, 2013, 07:16 PM   #13
sburt1928
zombie killer
sburt1928's Avatar
i did put in the one piece shaft.and after further reseach, i'm going too get the locker
Page generated in 0.33416 seconds with 62 queries
