TJ issues - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 1st, 2013, 08:36 PM   #1
pinktaco
Better than i deserve
pinktaco's Avatar
Default TJ issues
What do you guys do with a hard drivers side impact on a tj that breaks the motor mount off the engine block? Its cast I believe not really good for welding. Im putting one back together just want it to be reliable without replacing the bottom end.
pinktaco is offline   Reply With Quote
Old January 1st, 2013, 09:31 PM   #2
bdd1469
bdd
bdd1469's Avatar
A freind bought a tj that had the same problem.The seller cobbled it up by building a mount that used a few other tapped holes on that side.I know one of the holes he used was behind the power steering pump bracket. Good luck.
Old January 4th, 2013, 08:03 PM   #3
70inmotion
70inmotion's Avatar
M.O.R.E. offers a mount that uses extra holes on the block for extra strength. May work for you.
70inmotion is offline   Reply With Quote
Old January 4th, 2013, 10:00 PM   #4
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
i built a large plate for the side of the block for a buddy with same issue. lots of measuring and trail and error. ill see if i have any pics of it together and i may have the file still and could pass it on to you so you could have one cut. i dont think i still have it but ill check
Old January 4th, 2013, 11:06 PM   #5
pinktaco
pinktaco's Avatar
that would be awesome if you did.
Old January 5th, 2013, 10:48 AM   #6
Cool parts peddler
Ironman Offroad's Avatar
I have a used one of these if it will work.
http://browndogindustries.com/S2883L...cket-Left.aspx
$75.00 + the ride.
Dale
Old January 9th, 2013, 09:19 PM   #7
unclebeaner
$75.00 + the ride.
Dale
that is damn close to what i built i wish i would have seen this before all the work i did
Old January 9th, 2013, 10:17 PM   #8
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
If it was me I'd probably pick up a used motor and put it in. You don't know how bad it may be cracked.
Old January 16th, 2013, 09:25 PM   #9
pinktaco
pinktaco's Avatar
Bought the mount from Ironman it actually has 4 stronger mounting points than the orig mount worked perfect thanks Dale! I would recommend this to anyone with this issue it s a well made product even if you have to give the 150$ for it.
Page generated in 0.20313 seconds with 50 queries
