Project 1971 CJ5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 1st, 2013, 08:02 PM   #1
gigbag
Rust never sleeps !
gigbag's Avatar
Default Project 1971 CJ5
Sold my XJ a couple weeks ago and picked up this new project .
A 1971 CJ5 ..... The past owners replaced the old Dauntless V6 with a Chevy 4.3 V6 . It is right up to and thru the firewall. ( I will cut away the area and fab some new sheet metal for enough clearance to work on it . )
I hope to !
a. Replace the steering system with something more modern and powered .
.... Tilt wheel column , forward mounted gearbox , and linkage clearance for the exhaust .
b. Power brakes ... and disc brakes on fronts
c. Heat .... no heater core or lines .
d. Wiring .... replace hole wiring harness ! ( Everything is cut and cobbled together now )
Already got newer springs for it (4" lift )... will be putting them on soon ( old ones broken)
If anyone has any constructive ideas , I would love to hear them !
ID:	99995   Click image for larger version
ID:	99996   Click image for larger version
ID:	99997   Click image for larger version
ID:	99998   Click image for larger version
ID:	100000   Click image for larger version
gigbag is offline   Reply With Quote
Old March 6th, 2013, 05:19 PM   #2
gigbag
Rust never sleeps !
gigbag's Avatar
OK ... so I have the front clip off the CJ ....
I have two imidiot things I want to work on !
1. ..... I want to convert the manual brakes to power .
I have a booster , master cylinder , porportioning valve , and mount for the booster ... But now for the first major set back . The CJ has clutch and brake pedels that pivot thru the floor ! I am sure I will need to get a newer set-up that swings from above . But now how do I configure the clutch linkage for this ????? ... I have been thinking of going to a automatic trans ....but that leaves more questions ... T-400 or T700r4 ??? and what t-case do I use with that set up , that will work with the older style Dana 27 ???
2. ..... Steering column / power steering ..... I want to get rid of the rickitty old set-up that has the gear box mounted to the frame at the firewall , then runs a shaft forward to a pivot . I also will be putting in a steering column in out of a early 80's CJ or XJ that has tilt !
Anybody done this before or have some good ideas for it ?
Name:	CJ5 build 001.jpg
ID:	102801   Click image for larger version
Name:	CJ5 build 003.jpg
ID:	102802   Click image for larger version
Name:	CJ5 build 002.jpg
ID:	102803   Click image for larger version
Name:	CJ5 build 006.jpg
Old March 6th, 2013, 06:34 PM   #3
joe_jeep
welfare wheeler
joe_jeep's Avatar
most auto trannys are gonna be real long for that jeep and 4" lift.
go with a hydro clutch for it. get a pedal assembly from a newer cj.
Old March 6th, 2013, 06:38 PM   #4
capone
capone's Avatar
While searching power steering conversion for my Willys I found a lot of good information on this site: http://www.earlycj5.net/forums/forum.php
capone is offline   Reply With Quote
Old March 6th, 2013, 08:30 PM   #5
gigbag
Rust never sleeps !
gigbag's Avatar
That's something else I was thinking !
Old March 7th, 2013, 09:12 AM   #6
gigbag
Rust never sleeps !
gigbag's Avatar
Any ideas on the steering set-up ?
Old April 14th, 2013, 04:44 PM   #7
gigbag
Rust never sleeps !
gigbag's Avatar
Default Dressing the motor today
need to remove the frame mounted brake master from drivers side , but starting to look like I did something !
Name:	dressed engine 002.jpg
ID:	104458   Click image for larger version
Name:	dressed engine 005.jpg
Old September 20th, 2013, 09:55 AM   #8
low900rr
low900rr's Avatar
Any updates
Sent from my SCH-I535 using Tapatalk 2
low900rr is offline   Reply With Quote
Page generated in 0.24283 seconds with 48 queries
