2008 jk rubicon build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 30th, 2012, 11:01 PM   #1
jeepman2010
jeepman2010's Avatar
Default 2008 jk rubicon build
before starting
jeepman2010 is offline   Reply With Quote
Old December 30th, 2012, 11:08 PM   #2
Schoemann
Schoemann's Avatar
Nice Jeep! Excited to see the end product.
Schoemann is offline   Reply With Quote
Old January 1st, 2013, 02:23 PM   #3
jeepman2010
Default Im thinking ........any recomendations
Winch,teraflex lift,35 mtrs,wheel spacers,exhaust,maybe a chip,jcr sliders
Old January 1st, 2013, 02:26 PM   #4
reptile610
reptile610's Avatar
Send a message via AIM to reptile610 Send a message via MSN to reptile610 Send a message via Yahoo to reptile610
i'm a die hard fan of teraflex. well worth the money IMO. as for power i'd say intake, exhaust, and chip and you should never need more than that.
reptile610 is offline   Reply With Quote
Old January 1st, 2013, 02:59 PM   #5
beedle4
beedle4's Avatar
Cant go wrong with terraflex, Rock Krawler, clayton, synergy/poly all top notch.
Most do the superchips programer.
If you plan to off road much CAI may be a bad idea.
Exhaust, IMO mbrp has the best sound but there are plenty of options too.
Do your research on sliders, I belive JCR are body mounted. Lots have had issues with major body damage due to this type. Frame is the beefiest option. But ACE a local company has some really nice non body mounted (body mount mounted) bolt on, or frame weld on. Best deal and lifetime warranty as well.
Old January 1st, 2013, 02:59 PM   #6
beedle4
beedle4's Avatar
Oh and join jkowners.com if you have not yet.
Old January 1st, 2013, 03:43 PM   #7
1TFROT
1TFROT's Avatar
no wheel spacers. get the correct fitment wheels
have fun with the build
1TFROT is offline   Reply With Quote
Old January 1st, 2013, 04:14 PM   #8
beedle4
beedle4's Avatar
Long as they are bolt on spacers, NOT slip on you will be fine.
I have ran them on three different vehicles and never had an issue.
Be sure and clean the entire hub mounting surface very well. Install with red loc tite and torque to spec, re-check the torque a couple times as well.
The "best" ones to buy are Hub and wheel centric. This will have a area machined out to fit the trucks hub the same as a OEM wheel would. Then it also has the truck side lip on the spacer so that the wheel fits the same way.
Then you have hub centric that only fit the truck that way and the wheel surface is flat.
And last are lug centric where it has a large center bore to fit multiple vehicles. And the spacer will again be flat.(just as an aftermarket wheel would fit)
When properly installed you wont have issues with any of them.
Spidertrax is the most well known spacer, but any reputable company will do. I would suggest the hub/wheel centric for the best fit though. But the cost will be slightly higher with them.
Old January 1st, 2013, 06:43 PM   #9
1TFROT
1TFROT's Avatar
OR, get the correct fitment and do it right.
jmo
Old January 1st, 2013, 07:16 PM   #10
Tweeternpi
Tweeternpi's Avatar
Gears!! You will want to change the gears if you drive it everyday. Wife has a 2008 JK with 35's had to put in new gears to make it work right. Put in 5.13 gears. Hers is an auto. It has been reprogramed, CAI and Exhaust. It gets 18 MPH on the highway with all of this done. May want to sleeve the Front Axle as well.
Tweeternpi is online now   Reply With Quote
Old January 1st, 2013, 09:59 PM   #11
beedle4
beedle4's Avatar
With the 4:10 gears and the re-tune 35's were not bad at all. But now with my 37's I cant wait to get my 5:13's in.
And yes very wise investment would be at min some front axle C-gussets. Or better yet artic industries truss/gusset kit.
Old January 2nd, 2013, 07:39 AM   #12
Tweeternpi
Tweeternpi's Avatar
Just wait until you do the 5.13 you will wish you did it with the 35s.
Old January 2nd, 2013, 08:27 AM   #13
Cool parts peddler
Ironman Offroad's Avatar
35's, 4.10's and a 3.8 with a automatic sucks!!!!!!
The trans will not stay on OD at expressway speeds. Will not hold 75 mph without down shifting.
5.13's are the way to go.
Like stated above, Teraflex or Rock Krawler are very nice lifts, matched with 5100 Bilstein shocks for a great ride quality.
Old January 2nd, 2013, 08:08 PM   #14
jeepman2010
didnt find ace armor
Old January 2nd, 2013, 08:44 PM   #15
beedle4
beedle4's Avatar
http://www.aceengineeringandfab.com/
Old January 22nd, 2013, 09:06 AM   #16
jeepman2010
Default ordered some parts,lift and
ordered 2 1/2 inch complete teraflex lift kit,and spider winch mount,im going to cut front bumper anyone do this yet (ends),thinking mtr tires 35????stock rims with poison spyder spacers????
Old January 22nd, 2013, 05:43 PM   #17
dreezy
Haggard Fab
dreezy's Avatar
jmo
This
dreezy is online now   Reply With Quote
Old January 22nd, 2013, 06:52 PM   #18
alboy79
Where's your loyalty lie?
alboy79's Avatar
Location: Comstock Park, Michigan or 49321 for shipping
Jcr sliders mount to the body mounts as well as to the body.
http://www.jcroffroad.com/mm5/mercha...Code=JK-SL2-4D
Give me a call, ill set you up with a good price. 269-353-1185
"Skill that is untested does not equate to actual skill." Test yourself!
Don't tell me what you've done.
Show me what you can do.
alboy79 is offline   Reply With Quote
Old January 22nd, 2013, 08:04 PM   #19
oz97tj
Wasn't this attached?
oz97tj's Avatar
I have a Super chips programmer is sell. It doesn't work on my'12... PM me
********GLFWDA.org********
Old January 22nd, 2013, 11:11 PM   #20
dmoney
tj on 36 iroks
dmoney's Avatar
Location: fremont michigan about hour north of grand rapids
hey daddy-o i know you like them nice alumium rims but for real last time at rocks and valleys i seen a guy with 31s on alumium rims and the lug nuts pulled through the rim....im thinking u need some steellies....looks like maybe you can get a chip^.....and ive also been reading about the jk front axle sleeve alot and c gussets this may be something u wanna look into....and finally if i had your money i would throw mine away...
dmoney is offline   Reply With Quote
Page generated in 0.41131 seconds with 83 queries
