not your typical one ton yj build - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 10th, 2013, 07:10 PM   #41
vis_eclipse
ton yj
vis_eclipse's Avatar
fuel cell skid plate
vis_eclipse is offline   Reply With Quote
Old February 17th, 2013, 06:59 PM   #42
vis_eclipse
ton yj
gears set muffler on shafts in
Old March 8th, 2013, 06:52 PM   #43
vis_eclipse
ton yj
finally got it out here are a couple shots still needs a lil work but its close.
Old March 8th, 2013, 07:40 PM   #44
two_much_talk
sit down shut up and ...
two_much_talk's Avatar
Old March 8th, 2013, 08:25 PM   #45
chevotass
chevotass's Avatar
can you tell me that actual ride hieght of those creepy crawlers when they are on the rig
Old March 9th, 2013, 07:29 PM   #46
vis_eclipse
ton yj
depends on tire pressure but at the 5lbs i run like 38.5 if its up to 15-20 lbs its a bit more than 39
Old March 10th, 2013, 06:42 PM   #47
vis_eclipse
ton yj
Old March 11th, 2013, 11:24 AM   #48
disturbedsledneck
disturbedsledneck's Avatar
I have a few questions.. I am trying to learn as much as possible before I get rolling on my YJ build. I'm going 6.0/4l80/231 and leaf springs, that much I know.
What is your rear suspension setup, exactly?
Are those Waggy springs soa?
Is that the stock fuel tank, if so how does the diff clear at stuff?
What motor mounts did you use?
Who did your harness?
I'm still digging the build, keep up the good work.
Wouldn't mind seeing it in person some day.
disturbedsledneck is offline   Reply With Quote
Old March 14th, 2013, 02:48 PM   #49
vis_eclipse
ton yj
the rear springs are xj springs soa with trail gear shackle joints welded to a rear bumper i made.
the fuel cell is an rci 12Lx9Hx30W with a skid plate i made for it. diff barely clears by an inch or 2. i used novak-adapt motormounts and had them do the harness for me. both are made extremly well. you will need a corvette fuel filter/regulator wix part#33737 and dakota digital sgi-5 converter box for it to run like factory. novak sell both but at a premium.(i learned this the hard way)
Old March 14th, 2013, 03:34 PM   #50
disturbedsledneck
I was under the impression that the XJ springs would move the axle back farther than what it looks on yours. I like the setup you have, and the stance. Maybe that is the route I will go too.
I have the complete frame cut with my motor, so I may try and make the stock 6.0 motor mounts work somehow. It looks to me like I can make them work. I haven't seen anybody else going that route though, so I'm kind of curious if there's a reason that I'm not seeing.
Old March 15th, 2013, 06:51 PM   #51
vis_eclipse
ton yj
i have them flipped so it stretches the rear back about 2in and i have spring perches with mult. mounting holes for about another inch if ii flipped the spring around the other way it stretches it about 6"
Old March 19th, 2013, 06:50 PM   #52
vis_eclipse
ton yj
took it out for the shakedown test at bundy hill for their debut of the new mild to wild trail. everything work great.
Old March 19th, 2013, 08:19 PM   #53
Nice. How do you like the Creepys?
Old March 20th, 2013, 03:31 PM   #54
vis_eclipse
ton yj
im impressed they grab ahold of rocks great. not quite as good as the boggers in the sloppy stuff but thats expected.
Old March 20th, 2013, 04:14 PM   #55
Have you had them in sand and snow yet?
Old March 21st, 2013, 09:10 PM   #56
vis_eclipse
ton yj
yea they do good in the snow way better than the boggers i had, havnt had them in the sand yet
Old March 24th, 2013, 04:04 PM   #57
1997XJ
1997XJ's Avatar
Who's hunk of shit xj is that?
1997XJ is offline   Reply With Quote
Page generated in 0.58595 seconds with 75 queries
