not your typical one ton yj build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 29th, 2012, 06:51 PM   #1
vis_eclipse
ton yj
vis_eclipse's Avatar
Default not your typical one ton yj build
starting the rebuild of my offroad rig ive had for ~4 yrs. going from mud to rocks
here it is day one all it had was 3" body lift i6 ax15 bald m/t claws
it was built and 3 linked and soa on 35's last year but now its time to go bigger
starting the tear down
stripped down to bare frame
dana 60 front just finished welding the brakets on
spool for the 14 bolt
shaved 14 bolt spool installed
tub before prepping for impact orange paint
chevy 5.3 and sm465 to be mated with the np231
vis_eclipse is offline   Reply With Quote
Old December 29th, 2012, 07:29 PM   #2
vis_eclipse
ton yj
dana 60 with ballistics high steer arms
frame all cleaned up and painted in satan black with the crossmember/ skidplate i built out of 1x2 square tube 1/4" plate steel and 1/4" angle iron for support
here is the cross member i drilled the bottom holes bigger than the top and used allen head bolts so the bolt is recessed into the skid plate
here i have the motor trans and t-case mounted and rear axle in along with 2 of the 40" creepy crawler with some diy beadlocks
then just last week i got the dana 60 bolted up trac bar made and all the small things buttoned up and rolled it out to paint the tub
you can see how i mounted the rear shackles using trail gear creeper joints for the shackle mount.
painted the tub yesterday and today put it on the frame and mounted my metalcloak fenders these things are well worth the money as they give you not only vertical clearance but forward clearance too
Old December 29th, 2012, 07:45 PM   #3
Mclovin
"The Situation"
Mclovin's Avatar
where's the "not so typical" part ??
Old December 29th, 2012, 08:05 PM   #4
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
I was going to be nice and not say anything but that's what I was wondering.
Old December 29th, 2012, 08:09 PM   #5
1997XJ
1997XJ's Avatar
I like it
1997XJ is offline   Reply With Quote
Old December 29th, 2012, 08:23 PM   #6
19914x4blazer
ps4 tag chevytruckguy82
19914x4blazer's Avatar
looks good
19914x4blazer is offline   Reply With Quote
Old December 30th, 2012, 12:32 AM   #7
vis_eclipse
ton yj
because its not a rusted beat hacked up yj but its not immaculately built by a guy making 6 digits that just sends it off to a shop to be built either.
Old January 6th, 2013, 05:52 PM   #8
vis_eclipse
ton yj
just got knee surgery wed. which slowed up the process but still got a couple of things done this weekend.
shock hoops welded in as well as wiring harness installed
steering moved 2.5" forward (its not touching just looks like it)
cleaned up the unnecessary wiring in the cab mainly radio. started wiring the switches, power, and ignition.
also painted the grill. here is an overall pic of where i sit. still need to bridge the shock hoops tho.
Old January 6th, 2013, 06:01 PM   #9
Windsorf350
Rusty Racing
Windsorf350's Avatar
not bashing your thread or anything but why did you mount the engine so high? link clearance? It just seams really high. Looks like a fun project tho. ill keep an eye on this one.
Windsorf350 is offline   Reply With Quote
Old January 6th, 2013, 06:25 PM   #10
Really? I don't think it looks high. I'll take a closer look at mine.
Old January 6th, 2013, 06:33 PM   #11
robbietap
Looks good.
That's how a 5.3 will sit. Not much room between the plastic cover and the hood.
Nice lookin YJ.
robbietap is offline   Reply With Quote
Old January 6th, 2013, 06:35 PM   #12
Windsorf350
Rusty Racing
Originally Posted by robbietap View Post
Looks good.
Nice lookin YJ.
hmm. i guess ive never seen one. I just thought it looked high because of how close it is to the hood and considering it has a body lift. looks good anyways... continue lol
Old January 6th, 2013, 07:15 PM   #13
bacongrease
Am i still a Noob?
bacongrease's Avatar
How well did the anti wrap set up work in the rear? Doesnt look like it would have much leverage, but i guess looks can be decieving.
btw: good looking build
bacongrease is offline   Reply With Quote
Old January 6th, 2013, 07:29 PM   #14
robbietap
Frame and motor height based off of a Yj. Once the plastic was on the hood only cleared by 3 or 4 inches.
http://www.greatlakes4x4.com/attachm...1&d=1357518463
Old January 6th, 2013, 07:37 PM   #15
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
it's the "built not bought" sticker...that lets you know this guy is the real deal! What is does for me is let me know this guy can't afford to buy it. I bet he thinks he can make homemade McDonalds cheese burgers too!
Old January 6th, 2013, 07:44 PM   #16
chevotass
chevotass's Avatar
looks good. on your 14 bolt shave. are you going to modify the stock cover or buy an aftermarket one?
mine looked the same as yours the 1st time i shaved and plated one. without adding at least one hole down low i could not get it to seal. I added 2 small holes near the corners where the plate is welded to the housing. i made a custom cover out of 3/16" plate and it sealed great after that.
Old January 6th, 2013, 08:26 PM   #17
green50gt
Got rocks?
green50gt's Avatar
Looks neat. Subscribed.
I heart Jeeps
green50gt is online now   Reply With Quote
Old January 6th, 2013, 09:28 PM   #18
vis_eclipse
ton yj
its not done yet but i will take pics once done its not a typically designed anti wrap bar its a really cool design that doesnt hinder flex at all i think most ppl call it a bam bar.
it was so i could get the right tcase output shaft angle with the tummy tuck.
i was going to buy a blue torch fab builders kit.
pretty quick to judge someone arent we. i could easily pay to have a shop do it 5 times over but why when i have the ability to do so myself after work.
Old January 6th, 2013, 10:04 PM   #19
robbietap
Old January 6th, 2013, 10:54 PM   #20
1997XJ
1997XJ's Avatar
Who the hell welded those hoops on? those welds look like shit!!
Page generated in 0.53966 seconds with 84 queries
