99 f350 v10 exhaust issues - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 21st, 2012, 02:28 PM   #1
eagle-eye
Default 99 f350 v10 exhaust issues
Okay, so most of the studs for the manifolds were broken off far enough outside of the cylinder head that I was able to weld nuts on them and back them out. However 5 are broken off about an eighth inside the head. My question is, can I build up some weld in there without fcuking the aluminum all up or do I need to drill it..? The aluminum has great heat disbursement so I would imagine that it would be ok. But I don't want to do it then have to replace a cylinder head. Any advise is greatly appreciated!
eagle-eye is offline   Reply With Quote
Old December 21st, 2012, 03:44 PM   #2
GREASYHANDS
GREASYHANDS's Avatar
Yes that will work fine. I like to make a nipple stick out then center my nut over it.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old December 21st, 2012, 03:50 PM   #3
Bones
Bones's Avatar
another option that I am sure you don't want to hear, is to pull the heads and take them to a machine shop...
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old December 21st, 2012, 09:31 PM   #4
eagle-eye
So it won't mar the aluminum threads at all?
Old December 21st, 2012, 09:35 PM   #5
hamsmotorsports
hamsmotorsports's Avatar
No I have welded out lots of them that were broke in the head. Build it up past the head let cool weld nut remove.
hamsmotorsports is offline   Reply With Quote
Old December 21st, 2012, 09:37 PM   #6
special k
special k's Avatar
x2. let the nut turn compeletly back to normally color from glowing and sometimes just a wrench or socket works or sometimes an impact works better if you can get in to it.
Page generated in 0.27769 seconds with 41 queries
