14 ff e brake - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 20th, 2012, 10:11 AM   #1
Jeeper52
Budget, what budget?
Jeeper52's Avatar
Default 14 ff e brake
Has anyone done a disc brake conversion on a 14ff that used the eldorado calipers . Did you set up the e-brake how did you do it and what parts did you use. I'm in Ontario and have to pass a safety test this year and its included and must work. Is there a kit for a brake on a 241 t/c?
Old December 20th, 2012, 03:34 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
I have heard nothing but bad reviews on the Cadillac calipers. Easier to get a late model 14 bolt with disc and internal e brakes
Old December 20th, 2012, 03:46 PM   #3
liv2mx
i like jungle gym's.
liv2mx's Avatar
we did it on mikes jeep.never really worked right.they are pricey as hell and impossible to find cores to swap.
Old December 21st, 2012, 02:58 AM   #4
BigWheelBob
The 4 Wheel Drive Shop
BigWheelBob's Avatar
I have them on one of my 14's, and never really cared for them. As Jeepaholic said above, if you have to have them, get a later model rear end.
BigWheelBob is offline   Reply With Quote
Old December 25th, 2012, 07:51 AM   #5
RADRICK
RADRICK's Avatar
Caddy rear calipers will plague you with issues!
Old December 27th, 2012, 12:38 PM   #6
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Originally Posted by radrick View Post
caddy rear calipers will plague you with issues!
x2
Old December 30th, 2012, 01:11 PM   #7
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
could you use a line lock or does it have to be mechanical?
Old February 5th, 2013, 11:50 AM   #8
Jeeper52
Jeeper52's Avatar
It has to be a separate brake system. Ive used the calipers on an 86 p/U without the parking break and they worked perfectly. I even had to get an adjustable proportoning valve to tune down the rear breaks so they wouldnt lock up before the fronts would
Page generated in 0.24798 seconds with 47 queries
