Double cardon angle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 18th, 2012, 11:27 AM   #1
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
Default Double cardon angle
I have a xj front shaft shortened on the rear of my yj. How steep of an angle is acceptable? Trying to do a tummy tuck and its at about 25 deg but the tcase output shaft is pointed down about 7 deg. So the angle of double cardon is 18 at ride height, is that ok?
Old December 19th, 2012, 04:15 PM   #2
BigWheelBob
The 4 Wheel Drive Shop
BigWheelBob's Avatar
Hang your rear at full droop,and spin the shaft. If it dont bind, run it. Most of them will bind around 28-30 degrees. Also, sometimes when you do a tummy tuck, it is good to run a 1" motor mount lift, this will help the angle some also.
BigWheelBob is offline   Reply With Quote
Old December 19th, 2012, 08:49 PM   #3
wilinsonlevi
Team Thumbs Up
The problem is the motor trans and t case are hanging in jeep from cherry picker so I can't do full droop. I have it done now and my motor is up higher than normal. Not sure how high over stock since I'm working with bare frame and making my own mounts.
Page generated in 0.27875 seconds with 32 queries
