1997 jeep Cherokee 8" long arm lift 3/4 ton axles NEED GONE !!!!!$$$ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 16th, 2012, 01:13 PM   #1
pat4king
pat4king's Avatar
Default 1997 jeep Cherokee 8" long arm lift 3/4 ton axles NEED GONE !!!!!$$$
I have a tough jeep does amazing off road amazing suspension for dunes or any other wheeling still very driveable on street 1997 Cherokee with 201xxx miles on the body, motor has been replaced with a lower milage 4.0, solid AW4 auto trans, NP231J with a fresh HD SYE with less than 10 miles. Jeep has very little rust, small spot on rear hatch. floors are solid.Rear axle is a Ford D60 with disc brakes. Has Ruff Stuff anti wrap spring perches and the brakes are basically brand new. It is also welded and has 3.55 gears Front axle is a Ford HP D44. It has a tie rod made of 1.5x.25 dom that is over the knuckle with 3/4 heims. the axles has a truss for the upper link and hydro assist mount. The axle uses ballistic fab mounts with fully captured coils, double shear shock mounts. the lowerlink mounts have skids underneith. There is a draglink also made of 1.5x.25 with 3/4 heims and is bent at the box to be parrell with the ground. The axle has less then 300 miles since new ball joints, ujoints, calipers, rotors, spindle bearings. all bearings are timkn and seals are National. the pinion seal is a little leak but have a national nib. wheen rebuilt the brake brackets and knuckles were media blastedand painted with self etching primer. The whole axle has been wire wheeled and primed as well then all shot with flat black paint. The diff cover has been plated with 3/16ths and 1/8th. I have extra brake hardware and set of shafts. The axle has Warn Premium lock outs it has 3.55 gears and a welded carrier.
Track bar is 1.5" DOM with heims and has HD bracket.
Rear suspension is RE 4.5" leaf springs with 1" Currie HD shackles and 2" block
Front is a custom built 3 link with 2x.25 DOM lowers and 7/8x3/4 heims and 1.5x.25 DOM upper on drivers side with 3/4x3/4 heims. Uses 5.5" RE coils. Also a really nicely built custom HD crossmember
Tires are 35x12.50x16.5 BFG MT with good tread on black steel wagon wheels.
The jeep runs great and flexes awesome.
Also has a JCR steering box spacer with a newer steering box.
Nates4x4 rear bumper with dring tabs and hitch.
TNT unibody stiffeners.Custom hood vents.all the brake lines are brand new.
16-17 MPG call or txt pat 6169149122 trade for hd 3/4 ton truck or anything diesel lifted silverado 99+ text me for pics
pat4king is offline   Reply With Quote
Old December 16th, 2012, 02:33 PM   #2
creeping death
I'm that guy.
creeping death's Avatar
price?
if i missed it, please disregard this message.
Old December 16th, 2012, 02:45 PM   #3
puckett
puckett's Avatar
Originally Posted by creeping death View Post
price?
Looking for another project?
puckett is offline   Reply With Quote
Old December 16th, 2012, 03:08 PM   #4
cj65
cj65's Avatar
Need price per forum rules. If its best offer I'll offer a shotgun a dog and a slightly used wife lol.
Old December 16th, 2012, 03:52 PM   #5
creeping death
I'm that guy.
maybe.
Page generated in 0.32141 seconds with 38 queries
