SBC Chevy World Products PBM Block Aftermarket**SOLD*** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 15th, 2012, 05:23 PM   #1
dmcjeep
dmcjeep's Avatar
Default SBC Chevy World Products PBM Block Aftermarket**SOLD***
This is a new block that I took in trade on another motor that I had. I really do not have a use for it personally. This is pretty much a $3000 block. I am asking $1850. Might consider a trade for a quad. Not much else but if you want a trade let me know what you have. Here it is from the PBM web site:
http://www.pbmperformance.com/store....891&parent=902
WPI084130
specs>> 9.025 x 4.115 x 400 mains - billet splayed caps $2,987.94
TECHNICAL SPECIFICATIONS
Material: High density Cast Iron
Deck Height: 9.025" (standard Chevrolet)
Deck Thickness: .600" minimum
Cam Bearings: Std small block set Can be machined for 55MM.
Main Bearings: Std Chevrolet (350 & 400 style)
Camshaft Location: Stock
Lifter Bores: Indexed (stock .843" bore)
Bore: 3.990" (hone to 4.000") or 4.115" (hone to 4.125")
Maximum Bore: 4.200"
Cylinder Wall Thickness: (.200" @ 4.200" bore)
Water Jackets: Expanded for better cooling
Lubrication: New Relocated Priority main oiling system
Oil System Features: Integral boss for front feed, boss
for rear scavenge, rear main cap has provision for wet sump pump
Filtration: Integral mount for spin-on filter
Oil Pan Rails: Solid (stock width) can be clearanced for strokers
Crank Clearance: 4.000" stroke (H-beam steel rods)
Main Caps: Splayed Nodular iron 4-bolt (1/2") w / dowels or splayed billet
Fuel Pump: OEM mount
Starter: OEM mount
Motor Mounts: Dual (front and side)
Cylinder Head Stud/Bolt Holes: Blind tapped to prevent leaks
Weight: Iron: Approx 190 lbs.
dmcjeep is offline
Old December 25th, 2012, 09:43 AM   #2
dmcjeep
dmcjeep's Avatar
btt
dmcjeep is offline
Page generated in 0.20225 seconds with 29 queries
