YJ: Won't Start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 15th, 2012, 10:43 AM   #1
Jake16JA
Jake16JA's Avatar
Default Won't Start
Yesterday morning, I was warming up my 94 YJ 2.5L, right when I was ready to leave my RPM's and eventually stalled. I, then, started it up again where it only got to 200 RPM before stalling out. Now it won't turnover at all. I had recently replaced the fuel pump, so I had thought that it had come loose or the wires lost connection, but everything seemed to be fine. Now I'm stumped on what it might be, anyone had anything similar happen or have any suggestions?
Thank you for any help,
Jake
Jake16JA is offline   Reply With Quote
Old December 15th, 2012, 10:51 AM   #2
hawkscj5
Skinny Pedal Crawler
hawkscj5's Avatar
fuel pump will not stop it from turning over.any oil in it?
hawkscj5 is offline   Reply With Quote
Old December 15th, 2012, 10:55 AM   #3
KCameron13
Weekend Warrior
KCameron13's Avatar
Won't turn over or won't fire? If it won't turn over that's definitely not fuel related. If you mean it won't fire, get a fuel pressure gauge it could be the fuel pressure regulator. Make sure you have spark as well.
KCameron13 is offline   Reply With Quote
Old December 15th, 2012, 10:56 AM   #4
Suta99
Suta99's Avatar
Bad alternator dead battery
Old December 16th, 2012, 05:54 PM   #5
Jake16JA
Jake16JA's Avatar
I'm not the greatest with vehicles, but I believe it's just not firing.
There's definitely oil in it, altenator and battery are good as the radio and other electronics fire up when I try to start it.
I thought that I had replaced the fuel pump very recently a good detail to include.
Old December 16th, 2012, 06:28 PM   #6
Jake16JA
Jake16JA's Avatar
Check engine codes gave:
12- Battery disconnected within last 50 starts
33- Air Conditioning
55- End Transmission
Old December 16th, 2012, 07:41 PM   #7
Jake16JA
Jake16JA's Avatar
Fuel pressure seemed almost nonexistent, couldn't find a gauge to buy at this time, but it seems the fuel pressure regulator went bad. I didn't check but I'm pretty sure I have a spark because it fired up before, what I'm assuming, losing fuel pressure.
Thanks,
Jake
Old December 16th, 2012, 09:14 PM   #8
Suta99
Suta99's Avatar
Thanks,
Jake
How did you check the fuel pressure?
Old December 16th, 2012, 09:47 PM   #9
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Buy or rent a fuel pressure guage and read it while cranking the engine. It should be around 40 psi.
Old December 16th, 2012, 09:48 PM   #10
Rob the plumber
There is a schrader valve/test port on the fuel rail to attach the guage to.
Old December 17th, 2012, 12:17 AM   #11
KCameron13
Weekend Warrior
KCameron13's Avatar
Get a gauge and get an actual pressure measurement. If the pump assembly is new, and you hear it kick on when the key gets turned to the on position, I'd start with the fuel pressure regulator.
Old December 17th, 2012, 08:26 AM   #12
Jake16JA
Jake16JA's Avatar
Went ahead and bought a new fuel pressure regulator, after installation the jeep still didn't fire.
Old December 17th, 2012, 08:51 AM   #13
Suta99
Suta99's Avatar
Does the engine crank when you try to start it? Is it starting to crank slower now that you haven't got it running? May want to get a battery charger on it to top up the battery before it is completely dead. If you haven't done it lately go through your basic tuneup procedure. Fuel filter, spark plug wires, cap and rotor. If you now think you have fuel you don't have spark.
Old December 17th, 2012, 09:16 AM   #14
firehawk
Live Action!
firehawk's Avatar
Test fuel pressure!
You can borrow a gauge from the auto parts store.
Old December 17th, 2012, 09:19 AM   #15
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Test fuel pressure!
this! stop throwing parts at it and find out whats really wrong with it !
H.o.r.e
Old December 17th, 2012, 09:30 AM   #16
Rob the plumber
Originally Posted by bigbchevy View Post
this! Stop throwing parts at it and find out whats really wrong with it !
x2!
Old December 17th, 2012, 10:27 AM   #17
KCameron13
Weekend Warrior
KCameron13's Avatar
X3
You'll waste a lot of money just throwing parts at it. Find out what the actual issues are. Make sure you have proper fuel pressure and spark, then go from there. Just like it was stated above, auto parts stores lend these out if you don't have them, take advantage of that.
Old February 19th, 2013, 10:20 PM   #18
CB10101
CB10101's Avatar
Do you have any gas in the tank?
CB10101 is offline   Reply With Quote
Old February 20th, 2013, 12:48 AM   #19
XJsport95
Haters be my motivators!!
XJsport95's Avatar
First i would check the fuel pressure like everyone else says. If thats doesn't help i would turn my attention to the plugs, plug wires, and what almost sounds like a coil.
XJsport95 is offline   Reply With Quote
Page generated in 0.30148 seconds with 80 queries
