94 xj project $900 firm ***SOLD*** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 14th, 2012, 07:34 PM   #1
diesel fever
Default 94 xj project $900 firm ***SOLD***
1994 jeep xj 4.0 aw4 176k miles 4x4 4 inch rough country lift $900 firm located in Union City Michigan
I bought this jeep last fall for a winter beater and future trail rig, but I have since decided to go a different route. It had death wobble when i bought it so I replaced the following parts on the dana 30 up front right away.
wheel bearings
tie rods
ball joints
jks drop track bar and bracket
I also have replaced the starter and put in a gell cell battery
It does have a dana 35 rear axle with a lockright locker that has been trouble free.
32x11.50R15 bfg all terrains best one 3/32 tread mounted on black aluminum mb motoring rims.
I built a solid start to a front bumper out of some 6" C channel and mounted it on the front.
The windshield is cracked, there is no radio, and the rear doors don't work from the outside. I accidentally punched a hole in the top of the gas tank while removing the floor.
The engine runs great and the trans shifts great, it is wheelable as is.
This is not a suitable daily driver right now. After installing the sye I needed a longer rear drive shaft so I cut and extended one myself. Its plenty strong and is balanced enough to go for a test drive but I would not daily drive it until a proffesionally balanced drive shaft is installed.
The reason I am listing this as a project is I didn't realize when I bought it, but the floor is gone. I replaced the passenger floor myself and it turned out really well (pics below). I don't have the time or the barn space to work on it now, so I am letting it go for way less than I have into it. This is a good start to a solid trail rig. I should add that the interior has been removed but is currently piled up in the back of it.
I have a spare 96 model aw4 and np231 with 120k miles and a few misc. parts I'll throw in with the jeep.
Here is the floor after welding the panels in before I undercoated it
Here is after I scaled, wire wheeled, and undercoated the unibody rail before I welded in the sheets for flooring.
This is right after I pulled the carpet up and removed the piece of sheet steel the p/o put under the carpet so I couldn't tell the floor was gone.
Not looking for any trades, cash only. Delivery is available for $1.50 per loaded mile.
diesel fever is offline
Old December 14th, 2012, 11:36 PM   #2
drogers
drogers's Avatar
i know you said no trade but maybe for my 95 sas s10 project
drogers is offline
Old December 15th, 2012, 11:27 AM   #3
diesel fever
No thanks
Old December 16th, 2012, 09:58 AM   #4
diesel fever
Btt
Old December 17th, 2012, 12:59 PM   #5
diesel fever
Ttt
Old December 18th, 2012, 06:47 PM   #6
diesel fever
Old December 19th, 2012, 01:00 PM   #7
diesel fever
Old December 21st, 2012, 02:29 PM   #8
diesel fever
Ttt
Old December 22nd, 2012, 08:30 AM   #9
Seraphim Soldier
Always the hard way
Seraphim Soldier's Avatar
So there's Still a hole in the gas tank?
Seraphim Soldier is offline
Old December 22nd, 2012, 10:54 AM   #10
diesel fever
Yeah, it's on the top and is pretty small. I was using a sheet metal cutter on an air hammer to cut the rust spots out and it just barely caught it.
Old December 22nd, 2012, 11:12 AM   #11
diesel fever
Cut the rust spots out of the body I should say. I wasn't cutting rust spots out of the gas tank.
Old December 22nd, 2012, 12:07 PM   #12
98ZJ318
RIP 2-15 12:20 AM
98ZJ318's Avatar
So does it still have the deathwobble? Take any trades? Is the front bumper tied in or just bolted to the factory bumper holes?
98ZJ318 is offline
Old December 22nd, 2012, 02:28 PM   #13
diesel fever
The death wobble is gone. I'll trade for cash. The bumper is mounted using 3 bolts per mount. It's stronger than stock, but not as strong as some I've seen. I built it with the intentions of beefing it up later on.
Old December 23rd, 2012, 10:14 AM   #14
diesel fever
Bump
Old December 24th, 2012, 08:49 AM   #15
diesel fever
Bump
Old December 27th, 2012, 01:18 PM   #16
diesel fever
Bump
Old December 28th, 2012, 01:17 PM   #17
diesel fever
Lunch bump
Old December 30th, 2012, 08:59 AM   #18
diesel fever
Bump
Old January 1st, 2013, 02:36 PM   #19
diesel fever
new year bump
Old January 2nd, 2013, 01:22 PM   #20
diesel fever
Bump
Page generated in 0.26562 seconds with 83 queries
