Determining combined gvwr with truck and home made trailer. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 13th, 2012, 12:46 PM   #1
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Default Determining combined gvwr with truck and home made trailer.
I had some one ask me this the other day and i didn't really know what to say. I understand with a factory built truck/trailer you can easily add up weight ratings but how does it work with homemade trailers? My assumption would be that it goes off of the weight rating of the axle used....however that information is not always available.
I have looked around and not come up with definitive answers....any body have any idea or info?
Old December 13th, 2012, 12:49 PM   #2
curbdog17
Mini Van
curbdog17's Avatar
Tires rating may be the lowest rating.
Old December 13th, 2012, 01:08 PM   #3
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
With my setup my trailer is home made 2500 and under.....it just barely squeaks under 2500...axles are twin 4500lb units....tires are 8 ply and total somewhere just over 10k iirc.....so i would assume my trailer has a gvwr of 9k since that is the axle limit but i guess i don't reall know.
Old December 13th, 2012, 01:09 PM   #4
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
The 2500 is the empty weight used for plating purposes
Old December 13th, 2012, 01:15 PM   #5
hightech
Crawl 101
hightech's Avatar
Do believe axle rating only, dont know for shur and the lenght of tongue might factor in too
hightech is offline   Reply With Quote
Old December 13th, 2012, 01:46 PM   #6
GetItOffroadGMC
GetItOffroadGMC's Avatar
It would be determined by the lowest rated component of the trailer. Coupler, axle, or tires.
If it is a single axle trailer, with no brakes, the rating would be 2999, considering anything over 3k must have brakes.
GetItOffroadGMC is offline   Reply With Quote
Old December 13th, 2012, 06:24 PM   #7
in2deep
Hole tester
load it till it breaks then subtract 30%
Page generated in 0.28813 seconds with 44 queries
