Question about rehabing a trail.... - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Land Use > Rules, Regulations, Trail, and ORV Park Chat
Old December 12th, 2012, 05:12 PM   #1
RALLYMAN
Default Question about rehabing a trail....
I've got a trail on my property that goes up a hillside in the middle of the woods. It's starting to get rutted out from use and rain water runoff and I want to restore the ruts somewhat so that they aren't quite so deep. I can't get a dump truck back there to put down gravel or stone so I was thinking of buying bags of concrete and just laying the bags in the ruts.
I know this probably isn't the way to go so I'm open to suggestions, comments, opinions, etc.
Thanks!!!
RALLYMAN is offline   Reply With Quote
Old December 12th, 2012, 05:36 PM   #2
montecarlo33
The Violator
montecarlo33's Avatar
rent a dozer, bobcat, or tractor and fix it the proper way. Old bed springs with weight ontop makes a nice drag.
Old December 12th, 2012, 06:32 PM   #3
joe_jeep
welfare wheeler
joe_jeep's Avatar
an old fence gate with big rocks makes a good drag.
Old December 12th, 2012, 09:16 PM   #4
Bags of cement will turn into loose boulders.
Old January 6th, 2013, 02:20 PM   #5
kb8ymf
Not as old as Whiterhino
kb8ymf's Avatar
This is why trail building is so expensive.
You need 'water bars'. This s exactly what Southern 4WD Assn used to build up and down the trails in Tellico. Water bars consist of rock 'walls' built across the trail at a 70-80* angle. These walls are somewhat impervious to water run off. Their job is to divert the water off the trail an on to the surrounding vegetation and slowly seep through the ground to the bottom of the hill.
The number of these on each trail vary but are usually located near the location experiencing the greatest run off of water.
I'm sure there are some other methods also possibe but that's the one I am most familiar with.
I suspect you might be able to do this with logs but at some point they are going to rot and you'll end up starting over.
Do a search for water bars.
jim-kb8ymf
kb8ymf is offline   Reply With Quote
Old January 6th, 2013, 02:46 PM   #6
ssgtgaines
ssgtgaines's Avatar
Get a bigger rig.
ssgtgaines is offline   Reply With Quote
Page generated in 0.19156 seconds with 41 queries
