Relay question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 10th, 2012, 05:46 PM   #1
92FleXj
stacks stacked on stacks
92FleXj's Avatar
Default Relay question
I don't know much about electrical when it comes to anything...
What I have is a 12v motor. Only two wires one power and one ground. But when I reverse them the motor runs the opposite direction. I need to be able to control both directions and I'm hopping to be able to do that with one (return to neutral rocker)
Is this poss? If so what would I need? I have standard relays, 6 pole I think. Would they work?
If so any help would be great so I don't cook my truck!
Old December 10th, 2012, 06:42 PM   #2
jbsjunk
Little Member
jbsjunk's Avatar
I wonder if a power window switch would be up your alley? Power to the switch from a circuit breaker, ground and the switch should move power/ground to the motor from the switch changing direction. There should be rocker switches that can do this but I have no idea how to wire them.
I like the idea tho.
Old December 10th, 2012, 06:52 PM   #3
92FleXj
92FleXj's Avatar
Makes sense. But same problem. A widow switch usually had like6 poles.
Old December 10th, 2012, 06:57 PM   #4
Wheelman
Extreme Mudder
Wheelman's Avatar
Here you go.
http://lmgtfy.com/?q=wiring+a+12v+dc...+run+both+ways
Wheelman is offline   Reply With Quote
Old December 10th, 2012, 07:00 PM   #5
redhead_823
redhead_823's Avatar
redhead_823 is offline   Reply With Quote
Old December 10th, 2012, 07:11 PM   #6
jbsjunk
Little Member
jbsjunk's Avatar
Dug this up.
http://www.12volt-travel.com/knowled...to-a-dc-motor/
Old December 10th, 2012, 07:19 PM   #7
92FleXj
92FleXj's Avatar
Originally Posted by jbsjunk View Post
This is what I will look for! Looks the easiest.
Old December 10th, 2012, 07:21 PM   #8
jbsjunk
Little Member
jbsjunk's Avatar
It made sense after I stared at it a minute.
Old December 10th, 2012, 07:22 PM   #9
92FleXj
92FleXj's Avatar
Yea. I could do it with two switches but that's lame..
Old December 10th, 2012, 07:23 PM   #10
jbsjunk
Little Member
jbsjunk's Avatar
This way you would know one direction was off when the other was turned on.
Old December 11th, 2012, 04:12 PM   #11
92FleXj
92FleXj's Avatar
yeaaaaaa
Old December 11th, 2012, 06:10 PM   #12
Dylan
Dylan's Avatar
Make sure the switch is rated for the motors draw. You never mentioned what size motor you were running.
And just for future reference, that's not 6 poles. It's a double pole double throw switch. Also known as DTDP.
Old December 11th, 2012, 07:10 PM   #13
92FleXj
92FleXj's Avatar
i learned about the poles today at the electric supply.
im not sure the size but the guy at the shop sold me the biggest one he had in stock. all hooked up and working awesome!!!
Page generated in 0.30381 seconds with 62 queries
