ZJ D30 in a TJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 10th, 2012, 12:00 PM   #1
2fst4you
2fst4you's Avatar
Default ZJ D30 in a TJ
If I remember correctly a ZJ D30 will bolt in right into my TJ correct? Would be out of a 98
Also I know they have cv shafts will everything off my current axle bolt in (aussie locker, chromos, brakes etc)
Old December 10th, 2012, 12:11 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Iirc the sway bar brackets are different but yes. Everything will swap
Old December 10th, 2012, 12:11 PM   #3
Jeep ZJ
Jeep ZJ's Avatar
Bolt on and go brother. Yes you will have to either run the cup with a cv joint or put your yoke on it and use the u joint style. Those cv drive shafts are known to blow out. I recommend not using it.
Old December 10th, 2012, 02:13 PM   #4
2fst4you
2fst4you's Avatar
I plan on running all my stuff just wondering if they fit right in sounds like they do
Old December 10th, 2012, 06:13 PM   #5
tcxtreme1000
Mud Slut-Hit Every Hole!!
tcxtreme1000's Avatar
Why not get a HP30 out of an XJ
tcxtreme1000 is offline   Reply With Quote
Old December 10th, 2012, 06:21 PM   #6
Jeep ZJ
Jeep ZJ's Avatar
do what he says and get the right gears
Old December 10th, 2012, 07:21 PM   #7
2fst4you
2fst4you's Avatar
I would if I could find one with 3.73 gears
Old December 11th, 2012, 12:14 PM   #8
tcxtreme1000
Putting in a locker?
Old December 11th, 2012, 11:43 PM   #9
2fst4you
2fst4you's Avatar
Yes an aussie
Old December 12th, 2012, 12:46 AM   #10
yyj87
yyj87's Avatar
wait...
35s/auto/3.73s?
ewwwwwwwwwwwwwwwwwww!
yyj87 is offline   Reply With Quote
Old December 12th, 2012, 01:35 AM   #11
silveradoboy
Sam Brown
silveradoboy's Avatar
Originally Posted by yyj87 View Post
wait...
35s/auto/3.73s?
He has a 5 speed
silveradoboy is offline   Reply With Quote
Old December 12th, 2012, 03:14 AM   #12
2fst4you
2fst4you's Avatar
Still eww id like 4.88s but already regeared to 3.73 and dont want to spend the money on these axles to do it again
Old December 12th, 2012, 06:47 AM   #13
yyj87
yyj87's Avatar
imo 4.88s will be way to much! Have your driven anything re geared yet?
Find some 4cyl axles!
Ill look this weekend for some 4.11 r&p. I had had a few fr/rear spairs when i ran the d35.
Old December 12th, 2012, 06:50 AM   #14
bigbchevy
missmrgreenagain
bigbchevy's Avatar
H.o.r.e
Old December 12th, 2012, 06:55 AM   #15
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
You're taking shortcuts, which will cost you more in the long run. Do it right the first time.
Old December 12th, 2012, 07:32 AM   #16
masterbeatty
masterbeatty's Avatar
4.56 ftw
Old December 12th, 2012, 11:40 AM   #17
yyj87
yyj87's Avatar
This!
If you cannot afford it wait. It is worth it!
Old December 12th, 2012, 11:47 AM   #18
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Why 4.56 and not 4.88 when running 35s? I know 4.56 is more of an "in the middle" gearing for 35s but is that why it's best recommended over 4.88s?
Old December 12th, 2012, 11:53 AM   #19
montecarlo33
The Violator
montecarlo33's Avatar
4.88's in a dana 30 are prone to breakage because of the limited teeth.
Old December 12th, 2012, 12:35 PM   #20
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
This!
That's why he's going with 3.73s in the first place. The 3.73s are his current gears so he is saving money by just replacing his current front axle, rather than having to regear both. The regear will come eventually, just not with 1/4 ton axles.
Page generated in 0.27041 seconds with 83 queries
