what is a good replacement plug for 3v 06 5.4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 8th, 2012, 09:57 AM   #1
gsd rule
gsd rule
Default what is a good replacement plug for 3v 06 5.4
Need advice on what spark plug to put into a 2006 Ford F150 with a 5.4. Just don t want to put the same two peace junk spark plug back in the truck.
thanks in advance for any advice
gsd rule is offline   Reply With Quote
Old December 8th, 2012, 06:28 PM   #2
booblinker
Sore and Tired 24/7
booblinker's Avatar
Autolite HT1 is suppose to be redesigned to fix the problem, I believe it is one piece, and the bottom part that gets stuck is 10 tho smaller. Make sure you spend the money on the Lisle tool if you haven't done one before.
Old December 8th, 2012, 06:43 PM   #3
88fordman
88fordman's Avatar
Motorcraft is the only way to go. The I rarely break off a plug that has been replaced before. The plugs have been updated tons of times to their current level. Put a SMALL amount of anti seize on the lower part (not the threads) before you install them.
88fordman is offline   Reply With Quote
Old December 8th, 2012, 06:56 PM   #4
Tuff_F150
Tuff_F150's Avatar
champions are one piece too, motorcrafts are still welded two piece. not sure bout autolites,
Tuff_F150 is offline   Reply With Quote
Old December 8th, 2012, 07:13 PM   #5
88fordman
88fordman's Avatar
I know they are, but I have had to replace too many champions/autolites for misfire issues
after replacement.
Old December 9th, 2012, 07:27 PM   #6
frdboy
frdboy's Avatar
X2
I have fixed random mis-fire codes by replacing aftermarket plugs in these motors with OE plugs.
Old December 10th, 2012, 08:19 AM   #7
gsd rule
gsd rule
Thanks for all the information. I think I am going to go with motorcraft plugs
Page generated in 0.33982 seconds with 44 queries
