In a little bind.... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 7th, 2012, 08:11 PM   #1
2fst4you
2fst4you's Avatar
Default In a little bind....
Bent my lower C at R&V last time out and its time to make a decision as to whats the easiest on the wallet as well as most practical. I need the rig up and running by snofari!
Option 1: Cut off C and weld a new one off another housing on
Option 2: throw my gears chromos diff cover etc into a new housing and install all new bearings and seals if needed
Option 3: find a HP30 with 3.73s and put my parts into that axle
Do XJs come with 3.73s?
Old December 7th, 2012, 08:22 PM   #2
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
yes. i have one i would sell you but the passenger side upper mount has been changed. so it probably wouldnt work with out putting it back to stock
Old December 7th, 2012, 08:24 PM   #3
Nvrenuf
Nvrenuf's Avatar
Option 2 or 3
Why do you need to replace the bearings?
Old December 7th, 2012, 08:27 PM   #4
2fst4you
2fst4you's Avatar
I can put a new mount on it debating on going to a 3 link anyways. Only will change bearings if needed currently my axle has all new bearings and seals
Old December 7th, 2012, 08:30 PM   #5
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
2 or 3
Old December 7th, 2012, 08:37 PM   #6
hosejockey4506
Visiting Admin
the xj 3:73 i have is a LP. i have had 3 of them in the jeep and have yet to break a gear set. housings on the other hand...............................
Old December 7th, 2012, 08:37 PM   #7
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Get hosers axle and cut the mount of yours
H.o.r.e
Old December 7th, 2012, 08:42 PM   #8
2fst4you
2fst4you's Avatar
I only want the axle if its an hp I already have another lp
Old December 7th, 2012, 08:45 PM   #9
hosejockey4506
Visiting Admin
so why not use it??????
Old December 7th, 2012, 09:12 PM   #10
Tab
Tab's Avatar
When this is all done you need to grab the grinder and try to remove a c off one off the junk axles just to see how fun and easy it is. After a few hours of trying to keep everything usable you'll give up and never put it on a future list ever again.
Old December 7th, 2012, 09:13 PM   #11
hosejockey4506
Visiting Admin
x10
maybe ever x12 since its a pos dana 30, its a throw away axle
Old December 7th, 2012, 09:20 PM   #12
bono
bono's Avatar
option 1 sucks ass truck me
bono is offline   Reply With Quote
Old December 7th, 2012, 09:21 PM   #13
masterbeatty
masterbeatty's Avatar
Seriously put the lp in unless you act dumb when you wheel your fine.
Old December 7th, 2012, 09:23 PM   #14
bigbchevy
missmrgreenagain
bigbchevy's Avatar
I ran a lp30 for two years locked with 36s but I babied mine
H.o.r.e
Old December 7th, 2012, 09:35 PM   #15
2fst4you
2fst4you's Avatar
Figure with the money and work to get it regeared and to clean it up I could upgrade to a hp30 maybe not.....
I will take your guys word for it
Old December 7th, 2012, 09:37 PM   #16
2fst4you
2fst4you's Avatar
Ive ran it locked on 35s for 2 years one with stock shafts one with chromo's
Page generated in 0.25636 seconds with 71 queries
