86 CJ 7 3 link build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 7th, 2012, 03:53 AM   #1
Brad Smith
Brad Smith's Avatar
Default 86 CJ 7 3 link build
I have been working on this project for year and thought I would share it. We wheeled for a summer and it needed some major work. I startes with rebuilding the 258 motor, board it 40 over and some head work and a diffrent cam. I also cleaned up the frame and painted. I was gonna do a spring over but decided to 3 link the front and do a spring over on the rear. This winter I will be regearing the axles and putting in lcokers and building new roll cage. It won't let me add anymore picts I will try later. Let me what you guys think!
ID:	99255   Click image for larger version
ID:	99256   Click image for larger version
ID:	99257   Click image for larger version
ID:	99258   Click image for larger version
ID:	99260   Click image for larger version
ID:	99261   Click image for larger version
Brad Smith is offline   Reply With Quote
Old December 7th, 2012, 08:24 AM   #2
littletrucker
I'd hit that
littletrucker's Avatar
looks like some pretty beefy lower links, what size?
Old December 7th, 2012, 08:41 AM   #3
babyjp95
average guy
babyjp95's Avatar
Try up loading your photos to photobucket and copying the .img line under the pic and post it here. then u don't have to manage the amount of pics u load. it helped me when I did a build thread. looks like a great project btw.
babyjp95 is offline   Reply With Quote
Old December 8th, 2012, 12:30 AM   #4
Brad Smith
Brad Smith's Avatar
They are 2.5'' dom with 3/4 heims and 5/8 mis alinment spacer. I used 14'' fox coilovers, used heim joints all the links, and 1.25 dom for the tie rods with 5/8 heims with 1/2 miss alinement spacer. All of the bracket were ordered from ruff stuff they are some beefy brackets.
ID:	99299   Click image for larger version
ID:	99300   Click image for larger version
ID:	99301   Click image for larger version
ID:	99302   Click image for larger version
Old December 11th, 2012, 02:34 AM   #5
Brad Smith
Brad Smith's Avatar
Here are some finished for right now pics.
ID:	99433   Click image for larger version
ID:	99434   Click image for larger version
ID:	99435   Click image for larger version
ID:	99436   Click image for larger version
Old February 17th, 2013, 04:24 PM   #6
Brad Smith
Brad Smith's Avatar
Default Bumper Build
I recently had time to build a bumper. I used 8''x32''x1/2 steel plate for the winch to set on, 2''x4'' square tubing for the front, 2''x2''x5/16" angle iron to mount the bumper to the frame, 1''Dom for the winch line guide, and the tow rigs I found at carqeust
http://s1337.beta.photobucket.com/us...27088660105487
Old February 17th, 2013, 04:48 PM   #7
Brad Smith
Brad Smith's Avatar
Default picts
Not sure how to use the photo correctly, so I posted this way
ID:	102047   Click image for larger version
ID:	102048   Click image for larger version
ID:	102049   Click image for larger version
Old February 17th, 2013, 04:51 PM   #8
Brad Smith
Brad Smith's Avatar
Default Roll cage and gears
In the next couple weeks I am gonna build a new roll cage with the help of a few freinds, and 4.88 gears with yukon grizzly lock for the rear
Old February 17th, 2013, 05:18 PM   #9
Tom
Because racecar
Tom's Avatar
I love the color of this jeep! Bumper looks good too.
Old February 17th, 2013, 05:41 PM   #10
Brad Smith
Brad Smith's Avatar
Thanks, thats what color it was when I bought it, I need to find way to get the paint matched when it needs to be repainted. Hane not seen one this color yet
Old February 17th, 2013, 06:09 PM   #11
landj
GLFWDA,UFWDA,SOFO,MEMBER
landj's Avatar
Where you at snoblind?
landj is offline   Reply With Quote
Old February 17th, 2013, 07:47 PM   #12
From the pictures, it looks like the 'Citron Pearl' used on the 97 TJs...
Nice looking CJ
Old February 17th, 2013, 08:02 PM   #13
Brad Smith
Brad Smith's Avatar
Thanks, Not sure if it is that color I haven't seen a TJ that not saying there isn't one. It seems to have a gold color sometimes and then just a greenish sometimes but like it.
Old April 21st, 2013, 08:50 PM   #14
Brad Smith
Brad Smith's Avatar
Default Newer style intake
I have gotten the new locker or gears in yet or roll cage, but I found a intake and exhaust mainafold off a 83 waggy, it looks a alot nicer then the one that is on it. The old is a 78 model it has the exhaust and intake bolt to gether and some sort of fapper between them and the newer one just has a little tube between them. The final result was a awsome, it seemed to have more power and revs up a bit quicker. I have not drove it much because i had to go to work. Hope to do some wheeler later this week to see if it runs better. The pict is of the old style, I dont have pict of the new set up
Old June 26th, 2013, 02:48 AM   #15
Brad Smith
Brad Smith's Avatar
In the past couple months I and time to install 4.88 gears and a Yukon locker in the rear dana 44 and left the front open with matching gears. Shortly After install we went to Drummond and the jeep did awesome,
Old August 7th, 2013, 01:14 AM   #16
Brad Smith
Brad Smith's Avatar
Default Roll Cage
About a month ago we started building the cage, built with 1 3/4 DOM and 1 1/4 pipe
ID:	109070   Click image for larger version
ID:	109071   Click image for larger version
ID:	109072   Click image for larger version
ID:	109073   Click image for larger version
ID:	109075   Click image for larger version
ID:	109076   Click image for larger version
Old August 7th, 2013, 01:38 AM   #17
Brad Smith
Brad Smith's Avatar
Default Roll cage
Some more Picts, I used Als liner kit on the cage and my truck it is some good stuff.
ID:	109078   Click image for larger version
ID:	109079   Click image for larger version
ID:	109080   Click image for larger version
ID:	109081   Click image for larger version
ID:	109083   Click image for larger version
Old August 7th, 2013, 02:03 AM   #18
Brad Smith
Brad Smith's Avatar
Default Finished Cage
As of right now this is how it looks, I still need to tie the cage to the frame and might lower the seats down a little. I used corbeau 4 point seats belt tied into the cage also, envently I will replace seats or get them recovered. Thanks for all the help Kyle Nixon.
ID:	109086   Click image for larger version
Old August 7th, 2013, 02:14 AM   #19
Brad Smith
Brad Smith's Avatar
Default Limiting Straps
I recntly add some limiting straps from inner air lock, they are some heavy duty straps. Next on the to do list is a new anti wrap setup and bigger shocks for the rear end. After changing gears and lockers the jeep seems to like u joints so hopefully and better designed traction bar will help keep the axle from rotating, and the old shocks were to short.
ID:	109088   Click image for larger version
ID:	109089   Click image for larger version
ID:	109090   Click image for larger version
Page generated in 0.31167 seconds with 81 queries
