project: not cool name yet. sas chevy build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 6th, 2012, 02:07 PM   #1
in2deep
Hole tester
Default project: not cool name yet. sas chevy build
after owning it for 10 plus years its time to toss the ifs crap.
starting out with a 88 scsb k1500
stock looking small block
nv3500 trans 241 t case.
whats going under it
welded 60 rear with 4.10
front 79 60 4.10
241-241 doubler
links and coil overs in front shackel flip in rear
re centered h1 wheels and tires
pics to come
Old December 6th, 2012, 04:51 PM   #2
Ford rules
Ford rules's Avatar
Sounds cool
Old December 8th, 2012, 02:58 PM   #3
in2deep
Hole tester
after fighting bolts that havent been moved since it was in the factory i gave up and called a friend to drop off the old gas axe one side done minus the brackets.
have to take a break to clear out the smoke fill garage pics comeing
Old December 8th, 2012, 09:09 PM   #4
in2deep
Hole tester
well no turning back now
i do see a few problems to come my garage door is only 7 feet tall and
i was going to mount my link brackets on my trans crossmember but do to the doubler i may have to come up with a new plan
Old December 9th, 2012, 08:21 AM   #5
bluminade
Bluminade Has Arrived
bluminade's Avatar
a free d44 will still cost you more than a d60
bluminade is offline   Reply With Quote
Old December 9th, 2012, 10:29 AM   #6
jhnyquest
goof ball
jhnyquest's Avatar
This.
Old December 9th, 2012, 12:48 PM   #7
in2deep
Hole tester
ok you guys win and your probably right ill start looking for a ford hp 60 thats not stupid pricey any one have one with 4.10
Old December 12th, 2012, 11:42 PM   #8
in2deep
Hole tester
ifs shit is in the scrap pile still have to grind some on the frame and fix a few holes i made, and im picking up a 60 for the front later today.
Old December 18th, 2012, 04:35 PM   #9
in2deep
Hole tester
no much work has been done but i did get a 79 hp60, ordered 241 doubler kit from d d machine after duffy gave me a deal i couldnt pass also ordered a plasma cutter and last but not least a bunch of shit from ruff stuff
Old December 18th, 2012, 05:38 PM   #10
BIGDANE36
BUY MY TRUCK
BIGDANE36's Avatar
Nice! 60 gonna have to be rebuilt or is she ready to go and any upgrades on it or stock?
BIGDANE36 is offline   Reply With Quote
Old December 18th, 2012, 06:47 PM   #11
in2deep
Hole tester
going to take it apart and see but it looks good planing on u joints and all new breaks,
not sure what i am going to do on diff, open, welded or locker yet if i weld i dont think ill steer to well
Old December 19th, 2012, 11:36 AM   #12
in2deep
Hole tester
ok ive had pleanty of time to come up with a good project name. what to you guy come up with
Old December 19th, 2012, 03:47 PM   #13
in2deep
Hole tester
found my low oil pressure problem when hot pick up was loose in the pump i normaly weld the pick ups on but i didnt have a welder when i did the engine never again
Old December 19th, 2012, 05:46 PM   #14
vteckickin
just got dont sas my 96 chevy. looks good so far
vteckickin is offline   Reply With Quote
Old December 31st, 2012, 05:33 PM   #15
in2deep
Hole tester
buch of shiney new bling showed up. doubler kit from D.D machine i was going to just get a shaft from him but her made me a deal on the whole thing
ruff stuff hiems and brackets
cleaned up the frame
just a little to deep
Old December 31st, 2012, 05:36 PM   #16
in2deep
Hole tester
45 minutes later
now i need to find someone close that can weld aluminum so i can finish the first case and get it bolted up
Page generated in 0.28534 seconds with 71 queries
