Seafoam - Change Oil after use? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 5th, 2012, 10:06 PM   #1
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
Default Seafoam - Change Oil after use?
2002 Jeep Wrangler 4.0L 140k Miles
Hello all, today I decided to seafoam mt TJ and I gotta say I'm glad I did it because its safe to say that the engine had a lot of carbon build up from all the smoke. Anyways, I did an Oil Change about 5 months ago (Mobil 1 10W30) and before I Seafoamed, I checked the oil level, it was fine, and still very clean. I proceeded with the Seafoaming, 1/3 in the gas tank, 1/3 in the vaccume line, and 1/3 in the engine oil.
I was just curious if I should change my oil now since Seafoam is sitting in it. I've heard mixed reviews and I'm sure I will on here but my engine oil is still relatively clean after 5 months (and I do a lot of driving) so I was wondering if I should do this or not or just let it sit? Will this be safe?
Thanks
Catnip 0_o is offline   Reply With Quote
Old December 5th, 2012, 10:18 PM   #2
KCameron13
Weekend Warrior
KCameron13's Avatar
I always drove for a day with the seafoam in the oil then changed the oil.
KCameron13 is offline   Reply With Quote
Old December 6th, 2012, 01:20 AM   #3
cerial
Direct Drive FTW
cerial's Avatar
Risking your engine over $60 does not make sense to me. Change it at 3k like you normally do.
I have always treated seafoam as a annual pre filter treatment to be ran for less then 100 miles before the filter/fluid change. Usually put in a day or two before changing.
Here is some good reading:
http://www.seafoamsales.com/tech-info-gas-engines/
Old December 6th, 2012, 01:40 AM   #4
MilwaukeeF350
Dan
Had heard alot bad negative about sea foam in oil.
If it was me I would put 1 quart of ATF in oil then gentle drive highway for 50 miles then change oil then drive until 5,000 miles.
How many miles was that on oil?
Old December 6th, 2012, 02:19 AM   #5
snboarder113
snboarder113's Avatar
Sea foam thins the oil when added to it, drive nice for a couple of days to clean (dont beat on it) then change the oil and filter.
snboarder113 is offline   Reply With Quote
Old December 6th, 2012, 10:18 AM   #6
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
It's been in it for about 25 miles, I plan on changing it when I get home
Old December 6th, 2012, 10:32 AM   #7
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Good link!
I have been thinking about doing this but I always slap my hand when I reach for the Sea Foam because I am unsure about putting additives in the gas/oil, etc. Maybe it's time to try it out and see what happens.
Old December 6th, 2012, 10:51 AM   #8
tgmaul
tgmaul's Avatar
putting it in the gas tank is great, best way imo thins the oil,,,,, i dont want my oil thinned by anything, put that shit where it belongs in the gas tank
tgmaul is offline   Reply With Quote
Old December 6th, 2012, 11:51 AM   #9
yyj87
yyj87's Avatar
Seafoarm in my gas tank/vac line ended with a large nasy carbon stain in the driveway. Awesome!
I dont like adding things to oil.
yyj87 is offline   Reply With Quote
Old December 6th, 2012, 04:30 PM   #10
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
If you do end up doing it you will be fine, just be prepared for a LOT of smoke, I thought something was wrong but after the smoke cleared she ran like a bute
Page generated in 0.27163 seconds with 53 queries
