Anyone got an old suzuki lt 230 laying around? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 4th, 2012, 01:46 PM   #1
93xj4dr
93xj4dr's Avatar
Default Anyone got an old suzuki lt 230 laying around?
Hi all. About a month ago i picked up a sweet 86 or something suzuki lt230 quadsport for a good price. Brought it home, kicked it a few times n got it going, and commenced to flogging the hell out of it in the dunes behind my house. Long story short chain came off pinned in 3rd and there goes the crankcase.... I have a spare engine im in the process of building but further inspection of the rear suspension of the quad revealed a cracked pivot tube on the rear swingarm. If anybody has one of these laying around i have cash and id love to take it from you. Thanks.
93xj4dr is offline   Reply With Quote
Old December 4th, 2012, 01:49 PM   #2
93xj4dr
93xj4dr's Avatar
Oh and im also interested in any kind of suggestions on an easy or cheap fix for this. Thanks
Old December 4th, 2012, 01:58 PM   #3
dfm_13
dfm_13's Avatar
I did the same thing to my 87'
dfm_13 is offline   Reply With Quote
Old December 4th, 2012, 02:12 PM   #4
93xj4dr
93xj4dr's Avatar
yea i guess theyre good for that. O well i have plans for an .80 over piston, a cam and pipe and k&n filter for the new engine but its not gonna be much good with a junk swingarm. lol
Old December 4th, 2012, 08:47 PM   #5
bdd1469
bdd
bdd1469's Avatar
I might know of one.A freind owned it and the same thing happened.We welded the case back up and put it together.It was traded to another freind whos kid blew it up.I will see if he still has it,and what he wants for it.
Old December 5th, 2012, 09:00 AM   #6
93xj4dr
93xj4dr's Avatar
Cool. Thanks alot. If I cant find one in a few days i think im just gonna try my hand at fabbing something up. I have a welder at home and access to a lathe. Im thinking cut the old pivot tube off and machine a peice of 1/4 wall DOM tubing to fit the bearing races and weld it to the swingarm. While im at it maybe ill extend the arm a bit. Itll be a bit heavier but i wont toss a chain thru my case again. Plus if I extend the arm Ill have a better chance of not getting bucked off when the built engine goes in. lol
Old December 5th, 2012, 03:04 PM   #7
04PSD
aka Langford
04PSD's Avatar
My buddy has one in his shop that he has been thinking of getting rid of...it's an 86, 2 sets of plastics, fresh candy blue and silver vein powdercoat on everything, 2 engines, one was recently rebuilt, one needs rebuilt, wheels, tires everything. The only catch, it's all in parts. It's complete, but it's not put together, and it needs a new hardware kit.
He pulled it all apart to have the motor rebuilt and powdercoat everything, but he never got it all reassembled.
He wants $1000 for everything.
*edit*
sorry, I misread...his is a LT250, not a 230.
04PSD is offline   Reply With Quote
Old December 6th, 2012, 09:05 AM   #8
93xj4dr
93xj4dr's Avatar
that still a pretty sweet deal. If I had that kinda cash id pick it up. I think i may have found a solution to my swingarm issue anyways. The rest of the quads in good shape.... well, after i swap out the cases on the engine. Im in the process of getting a peice of 1/4 wall DOM tubing thats close to the size of the bearing race and rebuilding the swingarm with about an extra 2 or 3" on it. It should work pretty well.
Old December 7th, 2012, 01:45 PM   #9
93xj4dr
93xj4dr's Avatar
Getting tubing and flat stock today. Im hoping to have my new(ish) swingarm mocked up and tacked together tomorrow.
Old December 18th, 2012, 04:16 PM   #10
gforce
gforce's Avatar
Default 230
I have a 86 Beater that Ran,same issue.Chain came off,but this 1 only got the bolt on cover.Which if I dont Sell this 1 Cheap i will look 4 a cover a fix it!
Thanks!
Greg
231 690 5075
gforce is offline   Reply With Quote
Old December 21st, 2012, 07:09 AM   #11
93xj4dr
93xj4dr's Avatar
Id be interested but thats a long drive for me. If it was spring id think about it only cause id stop up by the dunes for a day or so but right now I wouldnt drive that far. Thanks for the offer tho. I basically just needed a swingarm because my pivot tube was cracked but I did some modificating and fabbing and built a new swingarm thats extended 2" and has a pivot tube machined from I believe 1/4 wall 1.5 dom tube. I havent had a chance to try it yet, not til the engine is fixed and built. But it looks cool on the quad. lol
Old December 21st, 2012, 07:16 AM   #12
93xj4dr
93xj4dr's Avatar
Greg if you do decide to put a new cover on it I'd check the swingarm bearings and carrier bearings in the rearend. And the sprockets. From what I understand these quads are hard to find without JB weld on the case and stator cover because they all do that. Bad bearings is the usual cause for the chain jumping off. I also have not found sh@t for a case saver/chain guard for these which is both surprising and kinda lame.
Old December 22nd, 2012, 06:50 PM   #13
Why YJ?
Don't be a wuss... HIT IT
Why YJ?'s Avatar
Found this is it helps.
http://www.facebook.com/photo.php?fb...type=1&theater
2005 LJ comp cut, 1 tons, etc...
Paul
www.teamhodges.com
Why YJ? is offline   Reply With Quote
Page generated in 0.44050 seconds with 62 queries
