Ford EFI 5.0L HO upper **FOUND** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 4th, 2012, 07:37 AM   #1
Default Ford EFI 5.0L HO upper **FOUND**
I bought a adapter to for my truck lower to fit a car upper. Now i need a 5.0 HO upper with the dressing .......throttle body, sensors etc attached to it.
Typically found on stangs, cougars, thunderbirds, mark vii
CheapThrillB2 is offline
Old December 4th, 2012, 08:58 AM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
I have the 5.0 upper
Jeepaholic is offline
Old December 4th, 2012, 09:03 AM   #3
I was told the 5.0L uppers in cars std vs ho are the same (cobra excluded). If that is the case then LKQ/weller is $35 for the upper.
But if I can find a lower gt40 (lightning or knock off) I can run the explorer upper which is better then the std or ho uppers.
I have a 5.8L truck 351, trying to get the motor hieght down. I can run a bcbronco intake adapter on my stock lower to fit a stock 5.0L upper car (exc cobra and explorer). Or find a gt40/lightning lower and not run an adapter at all.
Old December 4th, 2012, 09:18 AM   #4
edited title
Old December 4th, 2012, 09:23 AM   #5
Jeepaholic
Jeepaholic's Avatar
From research the lighting stuff is not worth the price vs the upgrade it is over the stock stuff so might as well spend the money on an aftermarket stuff. I have heard the trick flow knock off is not a bad piece and iirc is roughly $400 vs the lighting stuff will run roughly $300
Old December 4th, 2012, 09:24 AM   #6
Sounds like I really just need to find a 5.8L car upper/lower
or
Buy the bcbronco adapter and car upper-probably $200ish overall but rather not run the adapter
Esc since my 5.8L is just speed denisty
Old December 4th, 2012, 09:26 AM   #7
Jeepaholic
Jeepaholic's Avatar
That would be the best bang for the buck
Old December 4th, 2012, 10:35 AM   #8
firehawk
Live Action!
firehawk's Avatar
I think I have an explorer lower if that is the same.
firehawk is offline
Old December 4th, 2012, 10:36 AM   #9
It isnt between the 302 and 351. 351 are wider between the heads.
Old December 5th, 2012, 07:27 PM   #10
Old December 7th, 2012, 02:38 AM   #11
deathbypsi
Brian R.
deathbypsi's Avatar
John, Ford never made a efi 5.8 car intake other than the FMS GT40 stuff which is stupid money to buy.
I would get a boneyard Explorer intake setup and get the adapters to bolt to the heads.
On the 5.0 uppers...watch the bore size behind the throttlebody cuz some non HO 5.0 cars used a smaller choked down upper intake.
deathbypsi is offline
Old December 7th, 2012, 06:39 AM   #12
Ford produced the crown vic with the 5.8L in the mid 80s till the platform change in 91. Its was almost exclusive to police packaged vics.
Old December 7th, 2012, 06:41 AM   #13
Ive found the adapter at the intake to plenum, link for adapter intake to head?
Old December 7th, 2012, 01:22 PM   #14
deathbypsi
Brian R.
deathbypsi's Avatar
All of the 83-91 cop cars that got 5.8's were carbed. My grand father had a 90 cop car with a 351w in it and it had a 85 mustang GT style dual snorkel air cleaner on it with a 4 barrel.
Spacers.
http://www.flatlanderracing.com/pmespacers-01.html
http://www.pricemotorsport.com/html/..._adapters.html
Old December 8th, 2012, 05:44 PM   #15
littleXJ
littleXJ's Avatar
I know it isn't 100% what your looking for. I have intake (upper and lower) and fuel rails and injectors from a 5.0 stang cheap. shoot me a pm if any interest.
littleXJ is offline
Old December 9th, 2012, 12:32 PM   #16
I have a adapter coming for the truck lower to 5.0 upper.
Old December 12th, 2012, 11:03 AM   #17
. Is it the HO and has the throttle body etc on it?
Pm'd
Old December 12th, 2012, 11:08 AM   #18
bigbchevy
missmrgreenagain
bigbchevy's Avatar
I have a 5.0 ho upper
H.o.r.e
bigbchevy is offline
Old December 12th, 2012, 11:09 AM   #19
trailrail302
Im going FAST!!!
trailrail302's Avatar
I think I might have one. Ill trade ya for the shifters...
trailrail302 is offline
Old December 12th, 2012, 11:10 AM   #20
Jeepaholic
Jeepaholic's Avatar
I'll check yes HO and throttle body but removed the egr piece but might still have it. Be over your way soon too
Page generated in 0.32904 seconds with 83 queries
