Full Size Bronco - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 5th, 2012, 10:49 AM   #21
eshallbetter
We cut and turned the beams and plated the front and back side, added the front truss and gusseting, windowed the passenger side beam for the axle shaft, gusseted that window, replaced the bushing pivots with uniballs, clocked the diff, and built new radius arms that are welded to the beams. Everything in the suspension is ours, we did not buy anything. Thanks for the compliments.
Name:	blasted beams2.jpg
ID:	99151   Click image for larger version
Name:	blasted beams.jpg
ID:	99152   Click image for larger version
ID:	99154   Click image for larger version
eshallbetter is offline   Reply With Quote
Old December 5th, 2012, 10:53 AM   #22
FORD FLARESIDE
just hockey
FORD FLARESIDE's Avatar
What kind of joint is that on thend of your ttb's for the pivot?
Would you be interested in sharing some of your measurements on the "cut n turn"? I would like to compare them to mine to see where I am at.
Make sure you post pictures/video's when this is done. I like where you are going with it.
FYI..........I know of a place that has reasonable one piece frontends for that if you want to go lighter.
Old December 5th, 2012, 11:08 AM   #23
eshallbetter
Thanks, but I have all my glass already!
On the cut and turn it may be hard for me to answer... one, because I did it a long time ago and don't remember exactly, and 2, I did mine a little different than most. Most just move the lower balljoint mount out, I cut the beam itself and moved the whole end to correct camber. This keeps the balljoints in the same relation as stock so they are not misaligned in the spindle, but it necessitates clocking the differential in the housing. It takes more work but is the "correct" way to do it in my opinion, but both ways have been proven to work. Which method are you using for your cut and turn? Remember, the distance will be slightly different from one side to the other given the different beam lengths. You will also want to correct camber using the 0 shims. Also check out GoFastBroncos.com that is where I usually hang out and there is a wealth of C&T knowledge there.
Old December 5th, 2012, 01:30 PM   #24
FORD FLARESIDE
just hockey
Same,...............I mounted a front sub to my garage wall, and cycled the TTB through full droop and full compression, until it worked out at max for both. I don't know how much I moved them, but I can measure out geometry now that they are assembled. I like your trussing. I think I may do similar, but was wondering if it is really needed.
Old December 5th, 2012, 01:52 PM   #25
camccardell
tiger blood
camccardell's Avatar
you are a very, very sick man!
Where you gonna wheel that beast? Out west I assume
Old December 5th, 2012, 02:12 PM   #26
eshallbetter
Out west, Silverlake, the TORC series (The guys have agreed to let me run formula4x4 class with them even though it's illegal, they need truck count) Where ever it fits between trees...
Old December 5th, 2012, 05:07 PM   #27
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Nice work, on both of those rigs!!
RIP FULLSIZE4LIFE
Old December 5th, 2012, 11:21 PM   #28
Minnesota Rick
Minnesota Rick's Avatar
Default Porting steering gear.
Tonight I ported the Steering Gear for a ram. Erik welded and started installing the swingset steering.
ID:	99214   Click image for larger version
ID:	99215   Click image for larger version
ID:	99216   Click image for larger version
Minnesota Rick is offline   Reply With Quote
Old December 6th, 2012, 10:48 AM   #29
eshallbetter
Now all I need is the steering box mounted back up! Then I can finish getting the swingset steering in.
ID:	99222   Click image for larger version
ID:	99223   Click image for larger version
Old December 6th, 2012, 11:52 AM   #30
Joxracing
Joxracing's Avatar
lol, with the rules changing so rapidly Erik, you're bronco will be legal for that class by the time its finished...
Joxracing is offline   Reply With Quote
Old December 6th, 2012, 12:17 PM   #31
BOGDOG
BOGDOG's Avatar
Cool I look forward to seeing it. I have been going to a couple TORC races a year. I would still be driving a big Bronco everyday except for the price of gas.
Old December 10th, 2012, 03:45 PM   #32
eshallbetter
OK, I got the steering in on saturday night. It is a single swingset steering, and it should help drastically with the bumpsteer. The TTB's are notorious for horrible geometry, and this should get it down to about .125" bumpsteer rather than the inches the stock draglink will get you. Waiting on some more parts before I can continue on the driveline...
ID:	99424   Click image for larger version
ID:	99425   Click image for larger version
Old January 26th, 2013, 02:32 PM   #33
eshallbetter
Started doing the gearing but I wasn't going to spend the 280 bucks to buy a puller so we made one...
ID:	101134   Click image for larger version
ID:	101135   Click image for larger version
ID:	101136   Click image for larger version
Old January 26th, 2013, 02:37 PM   #34
eshallbetter
We started stripping the truck back down to do more plumbing and wiring.
Old January 26th, 2013, 02:38 PM   #35
eshallbetter
We also started stripping it down to work on more plumbing and wiring.
Edit: oops on the double post.
Name:	NAKED BRONCO.jpg
Page generated in 0.35933 seconds with 69 queries
