14 bolt disc conversion...rotors - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 3rd, 2012, 07:48 AM   #1
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Default 14 bolt disc conversion...rotors
Any reason why you couldn't put a 1ton rotor on instead of a 3/4ton one? The 1ton rotor is thicker......
Old December 3rd, 2012, 07:53 AM   #2
bigbchevy
missmrgreenagain
bigbchevy's Avatar
as long as its the same back space and dia
H.o.r.e
Old December 3rd, 2012, 08:01 AM   #3
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
X2, if you are using 3/4 ton brake parts ( caliper & mounting bracket) the 1 ton rotor won't work, bigger in diameter. Double check at the parts store though. I used all 3/4 brakes on my 14 bolt and it stopped great.
Old December 3rd, 2012, 08:51 AM   #4
Hoss Blazer
!SPARTY ON!
Outside diameter is .38 difference, height is .28 difference & thickness is .24 difference. So the 1 ton is bigger.
Old December 3rd, 2012, 09:23 AM   #5
deerebowtie
Unchained
deerebowtie's Avatar
hydroboost?
Old December 3rd, 2012, 09:42 AM   #6
Hoss Blazer
!SPARTY ON!
Originally Posted by deerebowtie View Post
hydroboost?
Not yet, unless you have one for sale! The reason I ask about the rotors is because I need to get a new set for the rear.
Old December 3rd, 2012, 10:30 AM   #7
tonkatruckon44s
tonkatruckon44s's Avatar
Okay so not to hijack your thread but i have heard that if you use bigger calipers on the rear you don't need to get a proportioning valve is that true.
tonkatruckon44s is offline   Reply With Quote
Old December 3rd, 2012, 12:29 PM   #8
Hoss Blazer
!SPARTY ON!
Bigger calipers...as in what? You can get bigger piston ones, but I'd always put a prop valve in.
Old December 3rd, 2012, 01:03 PM   #9
deerebowtie
Unchained
shoot me a pm, I think I can help hook you up with everything but the pump/lines for under 30$ but it has to wait until the weekend.
Old December 3rd, 2012, 04:32 PM   #10
BigBlockBlazer
Axle breakin' 101
Don't quote me but IIRC on my Blazer I used the stock prop valve but removed the piece inside that holds residual pressure for the drum setup.
Old December 4th, 2012, 12:40 AM   #11
tonkatruckon44s
Yes the bigger piston calipers off a 3/4 ton i already have the bigger calipers and rotors all i need is brake pads. I read somewhere to use bigger piston calipers on the front or rear i don't remember which but then its not a necessity to have a new prop valve.
Old December 4th, 2012, 12:55 AM   #12
tonkatruckon44s
Nvm i just found it on ord. You use the bigger piston caliper on the rear to even out the proportion.
Old December 20th, 2012, 10:59 AM   #13
Jeeper52
Budget, what budget?
Jeeper52's Avatar
you need a proportioning valve for the rear or they will lock up bfore the fronts even on my 3/4 t pick up
Old December 20th, 2012, 11:10 AM   #14
tom77cj5
tom77cj5's Avatar
Power slide:thumbup:
Old December 21st, 2012, 03:55 AM   #15
BigWheelBob
The 4 Wheel Drive Shop
BigWheelBob's Avatar
Really, there is alot of untrue here. The whole system depends on front brake setup, rear brake setup, and tire size believe it or not. The thing to do is not change more than you have to to start with, IE, just get your rear done with all the 3/4 ton parts. Then, just drive it. Not every truck needs a prop valve, and some, I have even bypassed the valve. Just try a few things to get it right for you, not every truck is the same.
BigWheelBob is offline   Reply With Quote
Old February 5th, 2013, 12:52 PM   #16
Jeeper52
Jeeper52's Avatar
I had to use the valve on My P/U because the rear would lock up before the fronts would .
Page generated in 0.31474 seconds with 71 queries
