2002 ford sport trac - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 2nd, 2012, 02:57 PM   #1
codymcvicar
codymcvicar's Avatar
Default 2002 ford sport trac
Does anybody know what year engines will work with a 02 sport trac?
It's a 4.0l 4x4. The timing chain tensioners are making a lot if noise.
What I was told, is its cheaper to change the engine.
Thanks!
codymcvicar is offline   Reply With Quote
Old December 2nd, 2012, 06:59 PM   #2
booblinker
Sore and Tired 24/7
booblinker's Avatar
Thanks!
If you put a used motor with over 100k in it you will have the same noise, all SOHC 4.0 Fords do it not long after 100k. If you have a good runner, and just has Timing chain noise, why pull the motor for a used motor, and not just pull you motor and do timing chains? And even If you have a High milage motor, and do put a used one in, I would do timing chains on that motor before installing it.
Old December 2nd, 2012, 08:02 PM   #3
MilwaukeeF350
Dan
DITTO ^
Why spend $500 on unknown engine while you could replace parts on 4.0L SOHC for about $300-400 then last you other 150-300K IF IF U keep change oil on right time and use 5w20 or 5w30 synth with motorcraft filter.
Old December 7th, 2012, 01:08 PM   #4
Ebs
You'll have to read up on it more, but I believe you can replace one or two of the tensioners with the engine in place. It's worth a shot considering the amount of work otherwise.
Old December 7th, 2012, 06:54 PM   #5
88fordman
88fordman's Avatar
depends on what chain is rattling.
88fordman is offline   Reply With Quote
Page generated in 0.21419 seconds with 38 queries
