Gm 10 bolt front axle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 1st, 2012, 09:38 PM   #1
blue79scottsdale
Default Gm 10 bolt front axle
I have a gm 10 bolt front axle, does not have manual hubs. I was curious if I could by a set and install them or do I need new hubs also?? And how do I determine the year of the axle? I got all the numbers cleaned up and wrote them down. Thanks Aaron
blue79scottsdale is offline   Reply With Quote
Old December 4th, 2012, 11:49 AM   #2
blue79scottsdale
anyone??
Old December 4th, 2012, 12:20 PM   #3
koochman450r
koochman450r's Avatar
Hubs are the same as a 44. It would be from 1980 or newer. They put 10 bolts until 92 in the k5 blazer and suburban
you won this battle.
Old December 6th, 2012, 04:50 PM   #4
blue79scottsdale
I was told it was from the 70's. Gotta put new ujoints in, and bearings. Can I install manual lockouts on the hubs I have??
Old December 6th, 2012, 09:55 PM   #5
koochman450r
If it's from the 70's its a 44. If its 30 spline inner axles and more of a stop sign diff cover its a 44. Round cover and 28 spline inner axles it's a 10 bolt. Manual lock outs will work on either.
Old December 6th, 2012, 10:21 PM   #6
HPandThrottle
have fun or die trying
HPandThrottle's Avatar
corporate 10 bolts have been installed in gm's since the early to mid 70's members of my family own both a 74 k5 and a 77 1/2 ton silverado that were purchased new by them and they do indeed have 28 spline 10 bolts yeas you can install lockouts they come with all needed hardware to install
HPandThrottle is offline   Reply With Quote
Old December 7th, 2012, 07:21 PM   #7
koochman450r
Well I never said I was smart! I was just stating info I was told.
Old December 8th, 2012, 11:19 AM   #8
blue79scottsdale
Thanks Guys!!
Old December 9th, 2012, 08:29 AM   #9
HPandThrottle
There is much I don't know just trying to help with what I do know when I can
Page generated in 0.18009 seconds with 50 queries
