What year 302s will fit my 71 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 30th, 2012, 10:54 PM   #1
booblinker
Sore and Tired 24/7
booblinker's Avatar
Default What year 302s will fit my 71
I have a 71 F100 with a 302, it runs good but doesn't sound good, per the mechanic I had fix it, I haven't picked it up yet, So I don't know if it is blown. But if the motor is done, I want to find a 302 to rebuild and throw in, anyways what years will my trans, and intake manifold bolt into?
booblinker is online now   Reply With Quote
Old December 1st, 2012, 12:56 AM   #2
deathbypsi
Brian R.
deathbypsi's Avatar
All 255,260,289,302 engines can use the same intakes...carb or efi. Any trans that bolts to a 302 will also fit any 255,260,289 and 351w.
Only thing you need to worry about is the change in balance around 1980. Up to 1980 all small blocks used a 28oz balance crank with matching flywhel/flexplate. After 1980 302's went to a 50oz balance. You can not mix 50oz balance motor with any early 28oz stuff .
Old December 1st, 2012, 06:21 AM   #3
bdd1469
bdd
bdd1469's Avatar
Wrong!!!! Early 64/65? 289 had a five bolt bolt pattern on the bell housing.Pretty bad when a chevy guy has to correct a ford question.
Old December 1st, 2012, 01:51 PM   #4
deathbypsi
Brian R.
deathbypsi's Avatar
My bad for forgetting about those needle in a hay stack motors........63 to early 65 fullsize fords with a 289 had the 5 bolt,true...good luck running across one of those though.
To the original poster though.... I would just look for a newer 351w to swap in place of the 302. Your trans and flywheel/flexplate will bolt up and all 351's are the same 28oz balance as early 302's. The intake wont swap over but the other 98% of the parts will. Easy upgrade for a nice bump in power.
Old December 1st, 2012, 08:39 PM   #5
bdd1469
bdd
bdd1469's Avatar
One of those needle in a haystack motors cost me a bunch of money and some grey hair,thats why I brought it up.lol
I bought a mint 77 Mustang 2 with a blown up 302 in it.It was clean as could be and 100% stock.I hated fords but figured any little car with a big motor should be fun.I bought a built 289 from a 65 mustang for it and was shocked when it wouldnt fit on the same engine stand the 302 just came off of.The v8 mustang 2 used a c4 with a tiny bellhousing,flexplate,and convertor.There was no way to use the 5 bolt 289 in the mustang 2 so I sold the whole project.
Old December 3rd, 2012, 12:34 AM   #6
booblinker
Sore and Tired 24/7
booblinker's Avatar
Hmmm, I was discussing the 351 idea earlier today, dunno why it didn't cross my mind before, if I'm doing a swap might as well add 49 CI
Old December 3rd, 2012, 03:39 AM   #7
cj65
cj65's Avatar
If you need it I have a great running 71 302 pm me if u want it.
Page generated in 0.33721 seconds with 44 queries
