steerable 9'' - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Ebay / Craigslist / Auction Links
Ebay / Craigslist / Auction Links Find something interesting on ebay or a classifieds website? Share it here.
Old November 30th, 2012, 02:55 PM   #1
dirty addiction
dirty addiction's Avatar
Default steerable 9''
steerable 9'' rearend with dana 44 knuckles off a scout set up for fourlink and hydralic steering 5:67 gears FRONT OR REAR STEER.$600 OBO http://grandrapids.craigslist.org/pts/3438309099.html
dirty addiction is offline   Reply With Quote
Old November 30th, 2012, 03:43 PM   #2
Wramblerguy
Wramblerguy's Avatar
What high pinion third is that?
3rd generation jeeper
Old November 30th, 2012, 04:19 PM   #3
dirty addiction
the 9'' axle came out of a fullsize ford truck.
Old November 30th, 2012, 06:28 PM   #4
pitbull2332
pitbull2332's Avatar
The rear axle is upside down in the pic. It is a standard low pinion 9"
pitbull2332 is offline   Reply With Quote
Old November 30th, 2012, 06:48 PM   #5
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
If it is low pinion the knuckles must be on upside down.
Sent from my PG86100 using Tapatalk 2
Old December 1st, 2012, 07:23 AM   #6
pitbull2332
Good call, Wonder how the pinion bearimgs get oil.
Old December 1st, 2012, 07:45 AM   #7
chadcooper55
Oil isn't the issue if it is flipped upside down
Old December 2nd, 2012, 10:31 AM   #8
Wramblerguy
Ya John
Old December 2nd, 2012, 05:17 PM   #9
chadcooper55
Ya John
Huh
Old December 3rd, 2012, 10:31 AM   #10
dirty addiction
there straight cut gears steve from misfittoys fab built two of them for his rock buggy one front one back
Old December 3rd, 2012, 08:12 PM   #11
chadcooper55
Straight or reverse cut gears make no difference. You can't flip a low pinion axle over and have the axle spin the correct way. The axle will go backwards.
Old December 3rd, 2012, 08:23 PM   #12
curbdog17
Mini Van
curbdog17's Avatar
Not if you drive in reverse........ Duh.
Old December 3rd, 2012, 08:24 PM   #13
Jeep ZJ
Jeep ZJ's Avatar
Old December 3rd, 2012, 08:58 PM   #14
GREASYHANDS
GREASYHANDS's Avatar
Thats why its for sale...... Duh!
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old December 5th, 2012, 07:59 AM   #15
dirty addiction
it was built for offroad use $500
Old December 5th, 2012, 11:02 AM   #16
chadcooper55
I don't think you understand, it doeant matter if it is for off-road use. If you put that in and put the vehicle in drive it will go backwards. The only way it will work is if you have a rear engine buggy.
Old December 18th, 2012, 10:42 AM   #17
dirty addiction
with the housing flipped upside down as a high pinion it works in the front and gets plenty of oil i no of a few front engine mud trucks useing them the old boss rail ran one for years hillbilly stomp is running a 9'' front axle right now and there is a geo tracker on racing junk that is running a 9'' front so it can be done and yes i have seen guys useing them with a rear engine buggy also like scoopy doo ... we pulled the housing apart the other day to check everything out and all looks good and found out it has 4:86 richmond pro gears andhas 31 spline axles .... also for case options i talked to a couple of the guys running this set up and two are running a dropcase, one a 208 and the other one was running a chain set up no case...
Old December 19th, 2012, 04:27 AM   #18
chadcooper55
When you put a low pinion rear axle in the front it has to stay low pinion. Just like the high pinion 60 I built for the rear of my last project. If you buy an aftermarket high pinion center for a 9" it will work and if you leave it as a low pinion for the front it will work. If you have a t case of some sort that will change the direction the front driveshaft spins you could flip the housing and make a rear low pinion a high pinion. If memory serves hillbilly stomp has a fabricated 9" housing, Dana 44 knuckles and a low pinion center section.
Old December 19th, 2012, 04:31 AM   #19
chadcooper55
Go put your truck on jackstands and put it in drive and pay attention to the direction the front driveshaft is spinning. Now spin the pinion on that axle the same direction and post back with the direction the tires are going.
Page generated in 0.32569 seconds with 79 queries
