8" OD stainless tubing - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 29th, 2012, 03:40 PM   #1
Brods
Default 8" OD stainless tubing
Looking for 8" OD thin wall (around 11 ga) 304 or 316 tubing. Need three to six feet. Felker in Wisconsin makes it but wants $100 crate fee on top of the cost of the tube. Must be 8" OD tube not pipe (8 5/8" OD)
Anybody know of any sources that may have drops?
Thanks.
Old November 29th, 2012, 04:46 PM   #2
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
8" tube is a tough one. Most process plants use sch 10 when they get up that big. 8" tube is high $ stuff.
Sent from my PG86100 using Tapatalk 2
Old November 29th, 2012, 06:03 PM   #3
Brods
$40 to $50 per foot is what we're finding.
Old November 29th, 2012, 06:06 PM   #4
Jeeper52
Budget, what budget?
Jeeper52's Avatar
what are you creating?
Old November 29th, 2012, 06:15 PM   #5
Brods
A little test filter. The tube will be used for the vessel, clear plastic tube for show and steel or stainless tube when the fluid being filtered would attack the plastic.
Old November 29th, 2012, 06:40 PM   #6
chadcooper55
Could try Columbia pipe or galloup. That is generally where we get our pipe from. Could also try northland process piping. They are a large stainless piping contracter and may have any drops. If it was smaller or sch 10-80 I could help you out.
Old November 29th, 2012, 06:58 PM   #7
dougstephvoor
Supreme Chancelor!
dougstephvoor's Avatar
Etna Supply
Columbia pipe
The Macomb group
J.O. Galloup Company
All major pipe vendors.
Please note, O.D. tube 8-inch is very rare, that is why it is expensive.
Supreme Chancellor!
dougstephvoor is offline   Reply With Quote
Old November 29th, 2012, 07:29 PM   #8
Jeeper52
Jeeper52's Avatar
could you get a sheet metal shop to roll some ss and weld the seam
Old November 29th, 2012, 07:40 PM   #9
chadcooper55
If it were me and I was going to be making very many of these filters I would figure out how to do it out of 8" sch 10. Way cheaper and more readily available.
Old November 30th, 2012, 06:49 AM   #10
GearDrive
A little slow
GearDrive's Avatar
Maybe try a heavy truck junkyard. There might be some semi tractors with 8 inch stacks.
GearDrive is offline   Reply With Quote
Old November 30th, 2012, 07:05 AM   #11
curt1656
Praise the lowered
curt1656's Avatar
I call BS! You're putting a single stack on your dodge diesel.
Old November 30th, 2012, 07:43 AM   #12
masterbeatty
masterbeatty's Avatar
Psh noone runs 8 inch single stacks thats crazy talk
Old November 30th, 2012, 12:05 PM   #13
Brods
Rong. Its for a pair of stacks like this. Single stacks just look goofy.
The plastic tube is driving the design that is why its 8 OD.
O-rings seal on the outside of the tube so a weld seam or any deformities on the outside of the tube are not going to fly.
Thanks for the sources. We normally use Galloup, Ferguson and Satterlund depending upon what piping products we're buying. Looks like Northern might be useful for some other work we farm out.
Old November 30th, 2012, 12:18 PM   #14
Bones
Bones's Avatar
Try this place. I have used them a lot. They will cut to any length, and have a random drop section.
http://www.woolfaircraft.com/index.html
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old November 30th, 2012, 12:42 PM   #15
Lousypirate
Whoop Whoop
Lousypirate's Avatar
or here. it's metric, but it is pretty close with a 200mm diameter...http://www.metricmetal.com/products/rn2391.htm
I've bought plenty of stainless tubing from them to use in EO fittings... nothing that monstrous though. recieve quickly after order.
Old November 30th, 2012, 01:37 PM   #16
Bones
Bones's Avatar
or www.speedymetals.com
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Page generated in 0.30700 seconds with 71 queries
