5.4 guru - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 28th, 2012, 08:02 PM   #1
hunter2005
Default 5.4 guru
98 E250 idles fine and no check engine light or anything but when you take off it has a small miss in it can power through it and cruses fine just at take off.
hunter2005 is offline   Reply With Quote
Old November 28th, 2012, 11:46 PM   #2
bdd1469
bdd
bdd1469's Avatar
My guess is a bad coil,they are a very common problem.
Old November 29th, 2012, 01:04 AM   #3
MilwaukeeF350
Dan
Have fun pull all coil packs in that van.
Pull and inspect for crack body if not then pull boot and spring off then add dielectric grease on both side of spring then put back in there.
And keep driving van with that issue will ruin your cat convertor fast. I drove mine for like 200 miles later to find 2 spark plugs hole were full of water on #5 #7 cylinders. After that mileage never went up until I remove cat convertor it was plugged fast.
Old November 29th, 2012, 04:24 PM   #4
hunter2005
thanks guys. i'll be checking it all this weekend. yea heard the coil packs are a pain in the ass to do.
Old November 29th, 2012, 04:27 PM   #5
Inspect pcv hoses. The pass side rot and create a leak.
Old November 29th, 2012, 06:02 PM   #6
bdd1469
bdd
bdd1469's Avatar
Not too bad if you have small hands.I havnt done them on a van,may be easier because the dog house comes off.Probobly will not be easier because that would be too easy.I think all you need is a 1/4 " ratcet with some extensions,a 1/4 " swival and 8mm,10mm sockets. You have to unplug the injectors to get some coils out.I would put some fresh spark plugs in there while your at it,anti seize them and make sure they are tight.These motors are known for blowing spark plugs out and taking the threads with them.
Put some dieleletric grease on the coils when you install them to keep moisture out.
Might want to look at your exaust manifold bolts also as they are probobly rusted to the point of breaking soon.
Old November 29th, 2012, 06:53 PM   #7
Id rather change plugs and coils on a van then a f150.
Old November 29th, 2012, 09:26 PM   #8
hunter2005
thanks again. just working all the bugs out. kicking around on ordering a ujoint offroad kit soon. so want to make sure everything is running good on it.
Old December 18th, 2012, 09:41 PM   #9
kevinr839
kevinr839's Avatar
How many miles on the plugs? We just had a truck at work doing the same thing and plugs and boots fixed it
kevinr839 is offline   Reply With Quote
Page generated in 0.18728 seconds with 51 queries
