rocker panel repair on a 96 1500 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 28th, 2012, 02:23 AM   #1
Ajhawk
Ajhawk's Avatar
Default rocker panel repair on a 96 1500
so my drivers side rockers have a nice size hole rusted through and gone, any suggestions as to what would be a cheap way to fix this and make it look decent? the only thing i have thought of is to cut out a solid patch so i have solid metal to weld to, patch it up, and then herculine it, seeing as where my fender flares would go is already herculined, i figured it would match the rest of the truck (id obv do the passenger side also) but if anyone else has any other simple ideas, throw them out there lol
Ajhawk is offline   Reply With Quote
Old November 28th, 2012, 04:19 AM   #2
rammanriley
rammanriley's Avatar
cut and weld. I tried to fiberglass mine and it bought me a couple years but i ended up biting the bullet and replacing them.
96 Ram 1500 ECSB 5.9l v8 4x4 On 35's
13 Dart Aero (turbo go fast)
rammanriley is offline   Reply With Quote
Old November 28th, 2012, 06:01 AM   #3
bigbchevy
missmrgreenagain
bigbchevy's Avatar
spray foam and bondo
H.o.r.e
Old November 28th, 2012, 02:49 PM   #4
Ajhawk
Ajhawk's Avatar
yeah thats what i was thinking ramman, i figured if i weld a solid bead all the way around it, grind it down a little, with the roughness of the herculine, youll never know it was patched.
Old November 28th, 2012, 06:07 PM   #5
rammanriley
I used bondo to smooth it out then Herculined it.
Sent From My Fingers To You're Screen Via Tapatalk2
Old November 28th, 2012, 07:41 PM   #6
in2deep
Hole tester
welding sucks 3m have a panel adhesive thats the shit plus rust is not able to form in the seam like it can with welding
Page generated in 0.18939 seconds with 41 queries
