F-350 manual hubs - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 20th, 2005, 10:03 AM   #1
amc78cj7
amc78cj7's Avatar
Default F-350 manual hubs
Anyone know where to find one or a set of 1978 Ford F-350 Dana 60 manual lock-out hubs? I have one that's one the way out for my high-pinion kingpin Dana 60.
Thanks.
Jeff
amc78cj7 is offline   Reply With Quote
Old December 20th, 2005, 10:49 AM   #2
Bones
Bones's Avatar
http://www.warn.com/truck/hubs/application_chart.shtml
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old December 20th, 2005, 01:30 PM   #3
amc78cj7
amc78cj7's Avatar
The warn site says -78-97 are the same locking hubs. Can it be so? If so, I'm calling around some junk yards.
Jeff
Old December 20th, 2005, 01:36 PM   #4
smasheromalley
smasheromalley's Avatar
Are the stock ones broken? Cause most of the time they just need to be disassembled and cleaned. Ive done it on my tracker, ramcharger, and F250. Its pretty simple to do.
O on the ramcharger I removed the full time locks and installed the milemarker part time locks from autozone. Still it was a breeze.
Old December 20th, 2005, 02:10 PM   #5
amc78cj7
amc78cj7's Avatar
The ring on the one side is pretty distorted and needs to be replaced. It will lock and unlock, but requires a lot of wiggle work. I'm just afraid it will fail sometime. Everything is clean and assembled right though, to your point.
Old December 20th, 2005, 02:30 PM   #6
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
They are the same as new fords (d50 and d60) and the chevy d60s.
Old December 20th, 2005, 06:37 PM   #7
Geno
If your goin to a junkyard, might as well look for a D50 you'll find this IFS
in a HD250
Finding a D60 in a yard is like hittin lottery.
Geno is offline   Reply With Quote
Old December 20th, 2005, 08:12 PM   #8
amc78cj7
amc78cj7's Avatar
Thanks guys. Have a Chevy 30 spline hub assembly on it's way. Hopefully you are right and it will bolt right on.
Old December 20th, 2005, 10:43 PM   #9
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
a friend borrowed my 78 ford d60 hub for snow blind last year to use on his chevy d60. it'll be fine.
Old December 27th, 2005, 07:53 PM   #10
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
in a HD250
there where alot of D50's that weren't IFS. I would just buy a new set, and not worry about junkyard ones.
Old December 27th, 2005, 09:04 PM   #11
amc78cj7
amc78cj7's Avatar
But new sets are around $200 a pair......
Old December 28th, 2005, 02:54 PM   #12
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Milemarker are $140 at National Tire.....but I know what you mean Jeff about trying to find them cheaper.
Page generated in 0.24345 seconds with 59 queries
