Suburban 2500 or Excursion V 10 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 26th, 2012, 09:29 AM   #1
GerkTJ
GerkTJ's Avatar
Default Suburban 2500 or Excursion V 10
thinking about one of these two SUV's to tow my travel trailer with. Anyone have any experiences good or bad to pass along?
GerkTJ is offline   Reply With Quote
Old November 26th, 2012, 02:08 PM   #2
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Paging jeep bratt.. Her excurison is a diesel. What size trailer?
Old November 26th, 2012, 02:23 PM   #3
kickstand
circling the drain
kickstand's Avatar
what year suburban?
I think the 2000+ suburban has a nicer interior and ride than the ford (I have same era pick up as excursion).
I haven't driven many excursions but they feel a bit more truck like to me, i'm sure both tow pretty similar.
I would get the suburban myself.
Old November 26th, 2012, 02:30 PM   #4
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Duraburb.
Old November 26th, 2012, 02:31 PM   #5
gmotox
gmotox's Avatar
I would say Suburban, they ride great, get decent mileage, and parts are less expensive.
Old November 26th, 2012, 02:41 PM   #6
14muddn
How often, far, and much are you towing? If you could get away with a half ton burban I'd go that route if it will also be a daily driver. The 3/4 ton will tow better but you will be giving up a lot of mileage with the 6.0 or 8.1 vs the 5.3, the 1/2 ton will also ride a lot better.
Old November 26th, 2012, 02:42 PM   #7
deerebowtie
Unchained
deerebowtie's Avatar
http://www.greatlakes4x4.com/showthr...t=supercharged
this, with 4 captains chairs.
Old November 26th, 2012, 05:12 PM   #8
GerkTJ
GerkTJ's Avatar
That's the problem, won't use it that much as it will be just a tow vechile. I have a 2011 Chevy 1/2 with a 5.3 and it isn't enough truck for the 8000 lb trailer. I'm leaning towards the Suburban with a 8.1, mileage will suck but you can never have too much power!!
Old November 26th, 2012, 05:55 PM   #9
rentalrider
rentalrider's Avatar
I have an '02 f350 7.3 and an '04 yukon xl (same size as suburban) with 6.0. I was very surprised how well the suburban towed my trailer (around 5000#). Mine has the 4 wheel steer but that shouldn't change anything. IMO the chevy has a more car-like interior but I personally prefer the ford interior.
Old April 7th, 2013, 08:33 PM   #10
Mudking
Mudking's Avatar
I have a 96' burb 2500 (454) and love it. I have a 26' enclosed that I haul with it. doesnt even sweat it...
I have driven excursions. I wouldnt buy a gas one (especially the 5.4) for towing. BUT if you get the 7.3 parts are more expensive.
if you can afford the 00+ model suburban I would go with that. and the 8.1 is over kill. the 6.0 would be fine for you and you would probably still get 14 unloaded.
Mudking is offline   Reply With Quote
Old April 7th, 2013, 08:41 PM   #11
kkodet
kkodet's Avatar
I'm loving my 7.3 diesel Excursion. I've owned both this and two Suburbans and would take the Excursion any day. Solid axle, leaf springs, and yes, more truck like.
Another thing to consider is whether the third row seat is important to you or not. It was a big factor with me since I tote around 6 kids. The rear doors on suburbans are just the short rear doors from a crew cab. Excursions have their own special rear doors that are longer and make it easier to get in the third row, which also has more room than a Suburban.
Another thing is what flavor you like your rear most cargo doors in. Most Suburban fans greatly prefer the barn doors for usability. Problem is they have a big post in the middle that limits visability. Excursions have a hatch on top and barn doors on bottom, best of both worlds!
Old April 7th, 2013, 10:12 PM   #12
bdd1469
bdd
bdd1469's Avatar
Suburban all the way. I maintain a pile of fords and wouldnt buy one of their trucks, unless I stold it and had a buyer in mind.
The v10 makes decent power but has all the typical ford problems. Coil packs, exaust studs that are a joke when new and a major pain later. The spark plugs blow out and take threads with them. The trans lines, brake lines,fuel lines all run behind the gas tank and are a pita to fix. Steering colums fall apart. Clutch perches explode. Seats dont hold up nearly as well as a gm product,imo.
I can give you a million reasons not to buy a ford. Cant think of any reason to buy a ford unless it's a smoking deal. Then I would resell asap.
The 8.1 sub with a 4L80 will probobly need a fuel pump at some point. Some early 8.1 had a bad rear main from the get go, most likely recalled. They get shitty gas mileage but probobly no worse then our v10. The 3/4 chevy will likely need some front end work by 100,000 miles, our fords are rebuilt twice by then and still dont drive as well as a used up chev. Im forced to like chevys because I make a living maintaining fords.
Old April 8th, 2013, 07:25 PM   #13
GerkTJ
GerkTJ's Avatar
I just bought a 2003 Suburban with the 6.0L and 4:10 gears. 137,000 miles on it . Drives and rides great!
Old April 8th, 2013, 07:34 PM   #14
Yeah cause GM didn't have similar problems .
In the end you will have everybody leaning different ways bias to their expeirences and what they were raised around.
Old April 8th, 2013, 07:50 PM   #15
kkodet
kkodet's Avatar
Exactly. Both are good vehicles, and both have their pros and cons.
Being that you are considering a gasser I'd probably lean towards a Suburban anyways. If you can pony up for a Diesel I'd be looking at a 7.3 Excursion or a 93-95 Suburban 6.5
Old April 8th, 2013, 08:07 PM   #16
muddinman56
blood,sweat and beers
muddinman56's Avatar
huge 1987 BBC suburban limo on 44\\\\\\\\\\'s - Great Lakes 4x4. The largest offroad forum in the Midwest
This
But I would go with the burb my grandpa has one with the 6.0 pulls our 26 foot boat no problem
It's a 2004
Old April 8th, 2013, 08:34 PM   #17
bdd1469
bdd
bdd1469's Avatar
True, but....... I know of several "nice" fords that have been scraped, traded in for a huge loss, or are sitting in the weeds because they have a bad gem. You can fix a exaust stud, you cant fix a ford, only put new parts on it.
To the op, google "ford, bad gem?" Before you spend a nickel. Then google 6.0 powerstroke lemon. Have fun reading. I refuse to spend "good" money on a ford when they screw their loyal customers like they have.
Old April 8th, 2013, 09:08 PM   #18
kickstand
circling the drain
kickstand's Avatar
I side strongly with bdd1469 on this one.
bdd1469 read a few posts up, he bought a suburban with a 6.0 in it.
I loved my superduty, until it went to shit in no time flat. Biggest issue was how quickly the truck was rendered useless by what appeared to be a bad GEM module.
I feel so lucky to have traded that truck in when I did and not gotten stuck with an 8,000 lbs heap of scrap in my front yard.
Old April 8th, 2013, 09:18 PM   #19
Every GM Gen III & IV thats passed through my garage has had at least 1 exhaust stud busted off, at one end of the head or the other. Just got an LS2 for my Jeep a couple weeks ago, and sure enough the front left and right studs are snapped off.
Old April 8th, 2013, 09:19 PM   #20
oops it appears a dude from texas decided to drag up a 5 month old post.lol...
Page generated in 0.47629 seconds with 84 queries
