gm 10 bolt pinion bearing replacement - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 25th, 2012, 02:14 PM   #1
Cheap5.0
Default gm 10 bolt pinion bearing replacement
I've got a 1999 silverado 1500, 5.3 4x4 with what I think is a bad rear pinion bearing(s). I watched a few videos on youtube of a whole 10 bolt rebuild and I see how the bearings are pressed in and out, but what I don't know is if I will have to run patterns, measure backlash, preload, etc....if I re-use everything but the bad bearings.
if this is over my head, anyone have a guess what a decent price would be for a shop to do the work if I bring them the axle?
Cheap5.0 is offline   Reply With Quote
Old November 25th, 2012, 03:14 PM   #2
Toyfish
Toyfish's Avatar
if u bring the parts the book rate is 6 hours to change the bearings so it would be $300 at the shop i work at in lapeer
Old November 28th, 2012, 04:12 PM   #3
4x4xdodgeman
Send a message via Yahoo to 4x4xdodgeman
just get bearings and races, crushsleeve , seal. its easy to do.
4x4xdodgeman is offline   Reply With Quote
Old November 28th, 2012, 04:26 PM   #4
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
I would open it up first to make sure it hasn't 'sploded. That era 10 bolts have a bad history of giving up the ghost. I would put the money into a semi-float 14 bolt from the same era with the same bolt pattern and gearing. They came in extended cab heavy half tons and are bullet proof for a half ton. U-joint, spring pads and break connections should bolt right up.
As for the pinion bearing replacement the hard part is getting the races out and proper amount of crush in the sleeve (buy more than one) to set pinion bearing pre-load.
Old December 2nd, 2012, 09:59 PM   #5
Toyfish
Toyfish's Avatar
well my boss bought the truck and not only does it need bearing the spiders gears r a little chewed up
Old December 3rd, 2012, 08:03 AM   #6
BigBlockBlazer
Axle breakin' 101
Typical.
Page generated in 0.18432 seconds with 41 queries
