Ring & Pinion Dana 44s - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 25th, 2012, 10:47 AM   #1
choppergar
choppergar's Avatar
Default Ring & Pinion Dana 44s
Went to Scout 2 Axles. Dana 44s around 1974.
Can I take the ring & pinion, out of my Wagoneer Dana 44 axles & put them in to my new scout danas?
Scout has 308 gears. Wagoneer has 410s & locker rear.
Both low pinion.
What I see, looks like it will work.
Tearing alxes apart now.
What do you think?
Thanks
Gar
choppergar is offline   Reply With Quote
Old November 25th, 2012, 11:02 AM   #2
joe_jeep
welfare wheeler
joe_jeep's Avatar
i would think all low pinions are the same. u will need the carriers with the correct gear sets. there is a case break 3.92 and up or 3.92 and down.
Old November 25th, 2012, 11:09 AM   #3
redhead_823
redhead_823's Avatar
You will have to use the carriers from the 410s. The carrier split is at 3.73/3.92 for Dana 44. Other than that, it should work. Oh, and make sure they're both 30 spline. I know the Scout axles are.
redhead_823 is offline   Reply With Quote
Page generated in 0.21791 seconds with 32 queries
