pinion pin/ center pin won't come out with 4:56s in my 8.25 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 22nd, 2012, 12:12 PM   #1
thekid95xj
thekid95xj's Avatar
Default pinion pin/ center pin won't come out with 4:56s in my 8.25
Anyone ever have this issue?
thekid95xj is offline   Reply With Quote
Old November 22nd, 2012, 01:36 PM   #2
Dylan
Dylan's Avatar
cross pin?
sometimes with thicker gears, the pin hits. I'm assuming you need to pull the pin to pull the c-clip and get the axle out? Try spinning it 180 deg. Some times one or two of the gears are ground down to allow the pin to slide in. Try rotating the pin, sometimes people grind the pin.
Old November 22nd, 2012, 01:59 PM   #3
HPandThrottle
have fun or die trying
HPandThrottle's Avatar
not to be a smartass but did you pull the roll pin out first
HPandThrottle is offline   Reply With Quote
Old November 22nd, 2012, 07:15 PM   #4
BigWheelBob
The 4 Wheel Drive Shop
BigWheelBob's Avatar
Here ya go.
BigWheelBob is offline   Reply With Quote
Old December 3rd, 2012, 09:37 AM   #5
thekid95xj
thekid95xj's Avatar
Got it.
Page generated in 0.17629 seconds with 39 queries
