1994 bronco D 60's - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 18th, 2012, 02:24 PM   #1
mfelsk1505
AMSOIL DEALER
mfelsk1505's Avatar
Default 1994 bronco D 60's
Selling my bronco. Looking to get something I can run down the road maybe for a dd or be able to drive to the trailes and parks.
It's a 94 ford Bronco
Engine- stock 302 ac delete, new water pump, twin 16in electric fans hooked to a F 350 radiator, intake ran into the cab, and long tube headers into a flow master muffler. One of the tubes on the driver side header is dented up pretty bad from the drive shaft but can be fixed
Front axle- 78-79 king pin 60 5.38 Yukon gears with an open carrier and new yoke 78-79 trailing arms with drop brackets
Rear axle- 78-79 ff 60 5.38 Yukon gears 35 spline Yukon axles with a full spool and new disk breaks
Lift- 3in body lift
front has 9in coils
Rear 5in block, flipped shackles, and an add a leaf
Drive shafts are custom with ALL new u joints
Trans- stock e40d
T case- stock bw1356
Tires- 44/18.5/16.5 fronts very low tread but hold air
Rear- 44/18.5/15 tires are groved and have around 12-13/32 of tread I have to put air in them about every 2 weeks. One has a pretty good gash in the side wall that has been patched
The top is in great shape! The motor to the rear window quit working and the release froze up so I took the tail gate off and scraped it.
$4500 obo or trade for a smaller rig would really like an early bronco for a rig or a decent ex or crew cab pu for a dd
mfelsk1505 is offline   Reply With Quote
Old November 20th, 2012, 07:19 AM   #2
mfelsk1505
AMSOIL DEALER
mfelsk1505's Avatar
Bump
Old November 22nd, 2012, 12:39 PM   #3
mfelsk1505
AMSOIL DEALER
mfelsk1505's Avatar
Bump
Page generated in 0.23189 seconds with 32 queries
